20 Most Recent HP Jornada 525 Pocket PC Questions & Answers
Jornada 525 has trouble start
this is a vary old product that nobody uses now. its like DoDo bird. why use this device, there is no service support at all on it. if compelled to use legacy devices, ask at HP so they can all be shocked, posting for this. here they are, REAL HP. https://h30434.www3.hp.com/ we are NOT HP at all here,
9/21/2017 10:49:19 AM • HP Jornada 525... • Answered on Sep 21, 2017
2answers
Jornada 525 and Windows Media Player 9
Only a hint. Did you check the small print via the downloads for Pocket PC on the Microsoft web pages? If you download from the regular OS pages they don't mention that certain Pocket PC generations are not supported. I noticed this but only on Media Player downloads fom the pocket PC pages but it takes time to find this more detailed info. http://www.microsoft.com/windowsmobile/resources/downloads/pocketpc/defau lt.mspx
9/29/2012 7:39:06 AM • HP Jornada 525... • Answered on Sep 29, 2012
Can I update jornada 525 to poquet pc 2002 ?
Unfortunately, the Jornada 525 cannot be upgraded to Pocket PC 2002. The Pocket PC 2002 operating system requires a handheld with a StrongARM processor. The Jornada 525 has a Hitachi SH-3 processor.
9/12/2005 6:39:46 PM • HP Jornada 525... • Answered on Sep 12, 2005
Serial port
there used to be serial-to-USB converters available... Perhaps you can get one of those. Then you could try top setup your IrDA device (InfraRed, if you have one) for your ActiveSync Connecttion.
9/12/2005 6:36:14 PM • HP Jornada 525... • Answered on Sep 12, 2005
Internet Explorer
Please re-check your Proxy seetings
9/12/2005 6:16:12 PM • HP Jornada 525... • Answered on Sep 12, 2005
CF for Jornada 525
The only advice that I could offer is to try those 2 Compact Flash cards on someone elses PocketPC. If they don't work then there must be something wrong with the cards. However, if they both work then there must be a problem with the CF slot on your Jornada. Try to test out some CF cards from an electronic store if they will let you. Yes, you do not need drivers for CF cards. A preferred CF list? Whomever told you this is blowing you off. People use all brands of CF cards from Viking, Scandisk, Lexar, Mr. Flash, etc. Sometimes there is a bad card and other times the CF slot is bad so check both of those out...
9/12/2005 5:52:13 PM • HP Jornada 525... • Answered on Sep 12, 2005
Display
Unfortunately, hp does not have similar software posted on the Jornada website: http://www.hp.com/cposupport/swindexes/hpjornada531628_swen.html that would change the 256 color display to any other option; sorry!
9/12/2005 5:36:50 PM • HP Jornada 525... • Answered on Sep 12, 2005
Hard reset...
While holding down the power button, press the reset button on the back. This will hard reset the 525 but you will loose everything in your ram.
9/12/2005 5:35:09 PM • HP Jornada 525... • Answered on Sep 12, 2005
Jornada 525 OS
To list your CE version, you can go to the Today screen and select the Start button to pull down the menu. Select Settings (not HP settings). From the Settings screen, select the System tab at the bottom. At the top of this page, select About. This will list your CE version. Mine is Version 3.0.9348 (Build 9616). It also will list the Processor (SH3) and Memory (15.87 MB).
9/12/2005 5:31:11 PM • HP Jornada 525... • Answered on Sep 12, 2005
Syncro Jornada 525
You can buy a USB cable for your Jornada. HP and thrid party vendors sell them. I bought one that has a cigarette lighter adapter to charge the Jornada also.
9/12/2005 4:58:50 PM • HP Jornada 525... • Answered on Sep 12, 2005
My HP Core i5 is turning on and off.
Question edited for clarity. Question moved to a HP Computer category. Normally an overheating issue. On a laptop, make sure it is on a hard surface and not on lap, bed or cushion. Vacuum or blow out the vents. On a desktop, remove the case, clean all the vents, make sure the fan spins and clean all the dust and fluff from the heatsink and fan with a clean 1" paint brush and vacuum or compressed air or preferably both.. Lots of other ideas here https://www.google.com/search?q=HP+Core+i5+is+turning+on+and+off ..
8/14/2022 5:58:59 PM • HP Computers &... • Answered Yesterday
Pc won't start and makes 4 beeps and 4 red blinking lights.
ok we got a modelHP EliteDesk 800 G1 SFF rebuiltgeneration 1, 2013.
8/13/2022 6:36:29 PM • HP Computers &... • Answered 2 days ago
2answers
Will blue tack actually remove mylar screw covers on the back of some HP laptops?
Question moved from Cars and Trucks category. Try duct tape which is about 4 times stronger than electrical tape which is designed to stick to itself. You could also use a blob of hot glue on a small bolt head which is the treatment used for repairing small dents in cars..
8/13/2022 5:12:55 PM • HP Computers &... • Answered 2 days ago
I am trying to watch naruto season one episode 26 but i cant find where to turn the languede to english
Please Explain in Details. Do you need to know where to find it? Do you want to see the english version of it?
8/13/2022 4:01:23 PM • HP Computers &... • Answered 2 days ago
Hp probook 4720s xt949ut broken screen that's partially black and heats up fast barely enough time to login to windows then powers off
probooks, , I have some elitebooks and are near same. the LCd is damaged, and hopeless to the extreme replace it is the only cure. broken means replacement, PC or TV or monitors. why not post photos of damage do the blinded text box tech can see what is wrong. these PC love to overheat if not cleaned out of all lint inside and all vents, fan and its larger radiator. the huge battery is no good we remove it , snap snap and run on AC power pack only. cured now, there I answered for top 3 causes, can do more mine has 20 modules insides that can short and if do the PC shuts down. any tech knows this and does the strip down test. ask
8/9/2022 9:38:15 PM • HP Computers &... • Answered on Aug 09, 2022
Hp dv6000 error Err2Err3
found it in a garage sale for $1? sure, it's old, and all old PC's die, lucky you the screen still works at all. (most do not) HP Pavilion dv6000 with horrible XP operating system, (virus magnet) 16 years old today, no hdd or battery lasted 16 years. the main large battery is dead. that old, so leave it out, run on AC power only until PC works right. next is that very dead RTC CMOS coin cell battery dead., this makes BIOS go crazy, and fail hard. when that fails it can not boot. the boot hDD , harddisk boot order is gone, in BIOS page of same name F11 will not work right if any things above bad. The HDD this old is no good.(that old) so it did no run for 16 long years and fail just not out of the blue. I bet it did not (unless serviced fully every 3 years) RTC battery is under bottommemory hatch page 127 https://www.manualslib.com/manual/1031591/Hp-Pavilion-Dv6000.html?page=127&term=rtc&selected=1#manual after a new battery (coin + pig tail type) f10 is the hot key for bios (power on , hammer F10)
  1. bios page 1 set time and date.
  2. set bios defaults.
  3. set PXE to disabled where seen.
  4. set boot order to hdd first.
  5. save
  6. exit bios, and cold boot PC and see HDD fail. as all do this old.
any PC shop can fix this, why not do that?
7/22/2022 11:34:05 AM • HP Computers &... • Answered on Jul 22, 2022
I want to buy the HP Laptop 17-cp0012nv (631N9EA). Does anyone know if it supports 32gb of ram and if I can add 2nd hdd? Is there any photo/video of the internal?
the manuals at HP.com cover all that, RTM?I have 3 SSD in my Dell but dell is best.2015 PC yearbest i can tell (hp , has horrid indexing)this is your pagehttps://support.hp.com/us-en/product/hp-17.3-inch-laptop-pc-17-cp0000/2100371514page 9 (service manual)Up to 16 GB of DDR4-3200, DDR4-2666, or DDR4-2400 dual-channel support 16 GB (8 × 2)means 2 sticks of 8max. RTM manual any time you want. no lack of facts there.now the space issue HDD/SSD ? (as a 2nd drive)page 2 states sold with 2 drive option new, HDD + SSD1 TB, 5400 rpm hard drive + 512 GB, PCIe, solid-state drive but it does show M.2 drive ,so SSD is M.2 car/drive.M.2 2280 solid-state drives (NGFF) up to 1TB possiblepage 37 see, M.2 slot ,for a SSD m.2that is it , so RTM and page 9 here http://h10032.www1.hp.com/ctg/Manual/c07605281.pdfssd and hdd both shown clearlyon mine it has DVD drive pulled and hdd caddy with SSD drivemaking mine 3 x SSD , but you have no dvd drive to do that trick but does now have m.2 slot for any SSD drive.good luck with all that.the service manual at HP.com is clear. and there24/7/365
7/21/2022 1:19:00 PM • HP Computers &... • Answered on Jul 21, 2022
First, I wanna thank you for your help. my model is Hp ProBook 450 G1 window 10 64 bit when I try to on WIFI it says we can't find wireless device on this pc
at home,work or at the airport (wifi)? wgn1, wild guess #1 , HOME ! (answering to home. well do all things wifi fail at home or just the G1. fails? if yes all fail, that is a wifi router problem. or forgot your log in credentials? No only G1 fails! did the G1 ever work for you at home everbefore??? hummmmmm buy used, and wifi dead? (history not told) did you know most old PCs have no wifi new this is a fact. it must be added, called a CARD (WIFI) 2014 made, 8 years old I see goons sell them used as new on amazoned. still used it is. sold new with on of these 4 HP allowed cards HP also bans, other cards (black listed by HP. (not good that)
  • Realtek 802.11 b/g/n (1x1)
  • Meditek 802.11 b/g/n (1x1) with Bluetooth v4.0 combo
  • Intel Dual Band Wireless-AC 3160 802.11 a/b/g/n/ac (1 x 1 ) WiFi with Bluetooth 4.0 combo
  • Intel Dual Band Wireless-N 7260AN 802.11 a/b/g/n (2 x 2) WiFi with Bluetooth 4.0 combo
test #1, go to device manager and see what wifi card is there. or missing, totally.. the driver must be there and from HP.com or it will not work. If w10 plug and play fails. using wired ETHERNET cable to the router this PC never oncc came with w10 , only w7 or W8 so how did W10 get here.? but lucky you , HP does have w10 64bit wifi drivers here, in fact, all drivers of this PC.. https://support.hp.com/us-en/drivers/selfservice/hp-probook-450-g1-notebook-pc/5405421 so next you ask how to get them if WIFI is dead now. well 2 ways. use the ethernet port to a cable same name to the router port same name. or get the drivers, using a working internet PC and copy them to a thumb drive then move the thumb drive to dead wifi PC and load them, ( 1 driver it is and matches 1 of 4 cards) here is the hit list 1: the card must be there. 2: and be a HP card. (others do fail) 3: and a matching driver loaded.. card/driver/OS matched and HP matched.. 4: and connect,. works. now. using proper credentials wifi that is how the cookie crumbles..
7/20/2022 6:48:31 PM • HP Computers &... • Answered on Jul 20, 2022
HP Jornada 525 Pocket PC Logo
14 questions posted
Top HP Computers & Internet Experts
Mehandi Husain ...
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Jornada HP
  • Jornada HP
Most Popular Question
internet explorer
  • Computers & Internet
