20 Most Recent HP Jornada 568 Pocket PC Questions & Answers
RTM
read the manual.
why not learn to use google, and search for your service manual
hint, its not at HP support ended what 7years ago.
its 16 years old now. why fool with something this old.?
if it works leave it be... no parts now. from HP, only used parts.
many used part are bad.
leaving one thing, google search,
The HP books exit on the web, (not HP)
here is a close match, btw, first google hit,, shock !
http://www.manualsdir.com/manuals/96365/hp-jornada-520.html?page=2
HP Jornada 568... | Answered on Mar 07, 2018
ask hp,?
we are not HP
we be fixya
keep in mind that thing you have is legacy obsolete.
here they are real HP;
https://h30434.www3.hp.com/
HP Jornada 568... | Answered on Dec 28, 2017
The PDA toy, 17 years old now, who uses something this old?
in what country, DLS varies by country and state
and the rules changed here, in 2005. (wiki it)
it's winter here, in USA< so.. you are on other half of earth. (lower)
most computers made for 42 years, , ALL use a RTC chip
same chip as in a wrist watch( close to same, very close)
this chip does all that magic even to the level of a
perpetual calendar ! wiki that.?
so the BIOS can set (all real PCs) all that and the OS too.
when you change the OS time and date it then goes to the
BIOS RTC page and changes it there so they are in sync.
they Sync, up,
I do not know where Any OS stores time, after all it be different in all 100's of OS made, and your old relic PDA , gawd knows.
your manual for Jornada
tells you on PAGE 13, when you reset the Jornada, or or run it the first time, it asks for time city and time zone.
what makes you think this toy device even does daylight saving time, (it have to do every city on earth to do that , no easy thing)
on a real computer here, we can set our clock to WWV time.
via the WWV or WWVH, radio site, here, "atomic time"
then it sets you per the daylight savings (bit set selection)
That is how it works best on a real PC. or notebook.
maybe your Toy PDA is set this way (page 101)
Using ActiveSync, you can synchronize information in Microsoft Outlook
or Microsoft Exchange on your desktop PC with information in Pocket
Outlook on your hp Jornada."
but wait MS shut all that down long ago......
I googled for you and found very little on the RTC functions of you PDA. (but it is too old now, really)
the manual only has very little on topic, (so is limited in features)
http://www.hp.com/ctg/Manual/bpia2371.pdf
my guess is you are looking for something that DOES NOT EXIST.
seem so, no? not in the official book
HP forum zero hits.
google zero hits.
last Jornada sold on ebay for $5 ,gets you 7 of them,
71cents (USD) each, less than 1 PEACH, here
they are not considered here, just trash.
HP Jornada 568... | Answered on Dec 14, 2017
Go back to former wmp.
HP Jornada 568... | Answered on Oct 16, 2017
why not ask at HP.com
the maker
why flash it at all?, if it works or did, why do that?
why risk a bad burn and bricking any PC.
link 4 here "forum"
"http://pcdied.com/index.html#HP_help
HP Jornada 568... | Answered on Apr 12, 2017
It's built into the system...
HP Jornada 568... | Answered on Apr 21, 2008
No, that "pop" is not normal after every sound.
All you have to do: Select Device Manager, select "Universal Serial Bus controlled". Re-install the USB driver from Active-Sync CD. That's it.
HP Jornada 568... | Answered on Sep 12, 2005
Weird! I would try an alternative Windows CE MP3 player such as Xaudio or PalmPlayer to see if they do the same thing. I have trouble believing it's hardware related because AFAIK the MP3 decoding is all done in software, but I guess it's possible.
I have had this happen to me at work. You need to backup your Jornada on the computer that works to sync (VERY IMPORTANT) and then hard reset the Jornada (which wipes it clean). Make sure that you put the name back into the Jornada identification (it will be wiped out by the hard reset). Then try to synch on the computer that can't synch except as Guest now. It should sync fine. Then you will need to sync on the computer that works to sync to restore the backup file. Then you will be back to normal. It is a pain. I don't know why it happens but I know this solution worked for me. Let us know if it works for you.
Maybe i should help, because i was solving similar problem with C-Series handheld from Compaq, which is almost the same. I am using Active sync 3.0 as the newer versions didnt work properly and i got no problem...
Hi, You need "localization" software: it translates system commands as well as provides virtual keybord layout, handwriting recognition. I am using PenReader and Polish Localization done by Paragon Software ( avaliable on Handango) ; they have Spanish version as well. Thaer are other companies which do same sort of software.
Start, Settings, Control Panel, Folder Options, see if you have the correct settings. Make sure the user ID is the same as you signed up with. Check to see if you are using the right password. Who do you currently have internet service with. Call them and have them go thru with you your settings. What version of IE do you have? You might want to update. Also did you recently download and install anything. If you downloaded anything from RealNetworks it will mess up your settings because they change some things so that they can access your computer anytime you are on the web. If you have firewall see if it is stopping access.
Maybe he's using ClearType and you aren't?
The Jornada 568 has its OS in masked ROM. There is not an upgrade available.
I have a Jornada 568 but I've never seen the behaviour you describe. Is it possible that you damaged or caught a small part when you installed the new battery? Your new battery, was that the small round battery or a battery pack on the back of the unit. "Resetting to Factory defaults" suggests that there is no power at all, doesn't it? If the small round watch battery is dead then that might effect the clock.
I have been using ActiveSync for several years now. From time to time I upgrade to the latest available version that I can find on the Microsoft website. I have been using version 3.8 for several months without major problems. So I can recommend for you to install version 3.8.
lots of words and means just Dead PC. fans spin.
HP model number HP touchsmart. (no model stated at all)
its dead PC and screen is dead.
most PCs from HP have external display port.
of some kind, Display port or others, the manual covers this but your PC model was not told nor service tag model. told.
The PC is dead, and seems the power button is bad too.
here are some steps used on all laptops
1: remove the huge battery in the lap top, do not make excuses how hard it is to unplug , you bought it so do what must be done,
2: use the AC power pack only, (unpugged for 1hour first)
then plug it in, this pack
3: the PC must not self turn on. so push the power button now see it manually turns on.
4 the BIOS HP logo page shows and BIOS screens work like ESC, F10, F11,
5: if screen is still dead, use the external monitor port and
the Fn+F4 button as the manual tells you to do.
no PC stated at all not even class of PC, desk or laptop. and no parts are free.
the TOUCHSMART word does not tell what you own
that name used back to 2007, 13 years long.
IS THIS AND AIO all in one PC,?
does it have a power pack that in in the line cord
is it the right pack for the AIO>?
AIO PCs only have a few parts inside that are standard, RAM and HDD, all else is HP custom, making them as hard to repair as laptops, lacking those parts custom.
first learn to identify a PC first then tinker.
see examples below.
HP Computers &... | Answered 4 hours ago
HP Jornada 568 Pocket PC Logo
Popular Tags
21 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Jornada HP
  • Jornada HP
Most Popular Question
operating system upgrade
  • Computers & Internet
