20 Most Recent HP Pavilion N5000 Series (f2111-60915) Keyboard Questions & Answers
2answers
HP Envy does not always charge up or work with adapter with battery removed. After 2 days it worked again as normal. Couple of months later same problem occurs. Adapter works good.
If the charger is working well, then the power cell is depleted. You will have to replace the power battery in the unit. See U-tube for instructions.
9/27/2021 2:42:04 PM • HP Computers &... • Answered 2 hours ago
HP all in one screen issues
Depends on model number, there are many different types.
9/26/2021 7:53:57 PM • HP Computers &... • Answered 20 hours ago
How do i connect magic jack to my hp chromebook 14
Will you try this https://play.google.com/store/apps/details?id=com.magicjack&hl=en_US&gl=US ? and give use your comeback
9/14/2021 4:59:10 AM • HP Computers &... • Answered on Sep 14, 2021
Hp monitor keeps going to sleep. How do I stop it from doing this?
Great reply from our Computer Guru Larry. Let's put it down here, because it is now solved :>)
  • all monitors made for 2 decades to that , and buy law in USA> called Energy Star compliance. NO PC told nor OS told w can not guess PC nor what OS you run. not ever. make and model PC not told nor if using VGA/DVI/HDMI or DP connections. wow 14 years and finally fails. (amazing luck there and 99% of 2007 monitors are now dead, 8hr/day ,365. the answer box 1 , is you can not do that. in the monitor. by law. hard coded. here see why./? see sleep loop inside MON firmware, yes there it is .https://pcdied.com/BIOS/e173flow1.jpg All monitors go to sleep for 2 reasons, PC went dead (by law) or PC actual is in sleep mode. all PC sold are coded (settings) to do that by law, OOBE (out of the box experience) by law. so if using windows are you? yes, then click CP control panel, the power setting an turn off sleep to the MON or learn to google?? or ask any kid ,they know for sure. windows 10 (but gee 2007 is XP or VistA) google how to turn off sleep in windows. that power menu , control every thing in the PC that can sleep. USB ports, Nic cards, Monitor GPU ports , HDD and more, and all your choice on 2nd day owned. on desk top we just end sleep by hitting space bar (easy close wide key) or wiggle the mouse. or if set right in same place, the power button ends sleep pushed fast. on some old PCs, letting USB sleep, makes mouse and keyboard dead. (painful) mouse usb, fails. to unsleep in device manager,, go to mouse then right click properties on it. tab power management , allow this device to wake the computes. and do not allow hibernate mode, in power settings, it things can get ugly fast now the ELEMENT in the room. the PC came with XP I bet, 90% did and if upgraded and the PC maker does not allow, w7 or w8 or w10 at all then the drivers are bad. and bad drivers LOVE TO FAIL FOR Sleep. NO PC told no OS told hp 27,is what? nada see why here https://www.hp.com/us-en/shop/plp/access... the rear of a MON shows a tag with true model a desktop has 6 sides, one side has the tag, even bottom side. not told that. the monitor tag will show model and p/n or sku.# and nnnnnnnn#ABA the ABA is the true product number that also shows and tells options in it DAY1 new. like how many ports there are and what kinds of ports. and more. example (sorry googe will not let me see one year of 2007 monitors or Id guess better (grin) HP 27" 3UA74AA#ABA (LED,) so is newer, your is CCFL lamps, 2007 most are. PC 2007 , HP Compaq dc7800??? W2007 MONITOR? I never saw a 27" LCD monitor in 2007 so... and google fails me to find it. 100s of 27" HP monitors, yours not told, nor cable type used (VGA):?
  • Anonymous Jul 29, 2021 short answer turn off sleep in PC. if that fails the GPU card drivers are wrong, corrupted or not for you current unstated OS
8/29/2021 3:09:13 PM • HP Computers &... • Answered on Aug 29, 2021
I have the disc for my Epsom dx3850 I want to install it onto my hp notebook via external CD player It just won't allow me to do it
In most cases it is preferable to download the latest installers from the manufacturer, as the CD is often out of date. If you use the CD, there is usually a Setup program on the CD that will install what it has. The setup manuals are here https://www.epson.co.uk/support?productID=1601#manuals
8/27/2021 12:09:59 PM • HP Computers &... • Answered on Aug 27, 2021
2answers
How do I fix my blank HP Pro 3420 AIO PC
I would say it is in need of a power supply repair.
8/9/2021 12:27:45 PM • HP Computers &... • Answered on Aug 09, 2021
2answers
HP ProLIant GL380 Gen9 does not start
all I have are questions, and list of tests. One VRM saw a short and shut down as it must, to not burn up.VRM job (partly) is to act as a FUSE. (pure electronics fuse)you must find what is shorted, for sure it is a module of any kind inside, if all USB port are unplugged,even USB cables can short, some system shut down like that, others just the VBUS chip to it shuts downnot sure if you have POE ethernet ports there?> nah not there, power over ethernet. so can not short outside.that new MOBO was it preloaded with RAM and CPU or DEPOPULATED ALL THINGS.
7/17/2021 5:59:16 PM • HP Computers &... • Answered on Jul 17, 2021
HP Pavilion Gaming Desktop flashes green power button every 5 seconds and monitor screen remains blank?
If you are using win 10 force close it twice with the power button , turn it on as soon as it beeps use the power button to switch it off , do this two times , this should bring up the repair windows repair screen and give the option of removing the update .
7/17/2021 1:40:26 PM • HP Computers &... • Answered on Jul 17, 2021
2answers
Free download music for pc
music download software http://100-downloads.com/download.php?p=682 spotify Instant and legal access to over 10 million music tracks http://www.artistdirect.com/music http://mobile.afreecodec.com/free-songs-download-87079.html once the music starts to download a browse option will open where you will need to select if you want to run or safe
you should always keep your antivirus up to date when using any file sharing programs on the internet
hope this helps
7/13/2021 6:03:36 AM • HP Computers &... • Answered on Jul 13, 2021
2answers
Pm5 is not opening, asking netware error pm5.exe
A Netware error was dected. Please verify that you are properly logged in. See the network Installation guide for more information
6/28/2021 1:31:06 PM • HP Computers &... • Answered on Jun 28, 2021
3answers
HP Compaq Elite 8300 sff Solid red light and then powers off
The battery is shorted out
6/10/2021 1:43:08 PM • HP Computers &... • Answered on Jun 10, 2021
I have a HP ENvy 7645 Printer. It has been removed from my laptop. I want to add back. The touch screen will not work. Where can I find the WPS PIN number to add.
the WPS is only in one place, INSIDE unstated ROuter. tell router make and model # and get exact answers. only. answering for printer connected to router, wifi direct. Ive no idea what modes you are using do you have the manual, for setup seen on HP,? its there. we are not HP here it is. in all its glory./ https://support.hp.com/us-en/product/HP-ENVY-7640-e-All-in-One-Printer-series/6617267/model/6779508
6/10/2021 1:29:17 PM • HP Computers &... • Answered on Jun 10, 2021
3answers
How to Fix HP Laptop Cooling Fan Error?
  1. If you notice that the system fan spins and is blowing warm air from the computer, clean the exterior vents to remove dust buildup by blowing air through the vent openings.
  2. Perform a hard reset.
  3. In some cases, updating the BIOS may help prevent this error from occurring.
6/10/2021 1:24:15 PM • HP Computers &... • Answered on Jun 10, 2021
My hp windows 10 laptop some keys are not working like H , G ,BACKSPACE ,VOLUME DOWN
The keys on your laptop computer needs to be replaced and have a person that repairs and fixes computers to have a look at your laptop and see if the keys can be repaired or not for your laptop.
5/4/2021 12:22:38 PM • HP Computers &... • Answered on May 04, 2021
HP Pavilion N5000 Series (f2111-60915) Keyboard Logo
1 questions posted
Top HP Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
dvd region locked
  • Computers & Internet
