20 Most Recent HP (FA162A#AC3) for HP iPAQ 2200/4100 Keyboard Questions & Answers
For use with TTN you'll need the following: -A GPS mouse (either wired or wireless if you have bluetooth on your ipaq) -TomTom software -Memory card (usually Secure Digital of Compact Flash) to store the differents maps on it. It's also recommended to have a card reader on your pc to transfer the maps on the expansion card. Good luck and let me know if it works out or not
HP (FA162A#AC3)... • Answered on Sep 19, 2005
The keys on your laptop computer needs to be replaced and have a person that repairs and fixes computers to have a look at your laptop and see if the keys can be repaired or not for your laptop.
HP Computers &... • Answered on May 04, 2021
windows 7??????????????????????i went to hp.com and there is only XP and W7 support on this 12 year old pC, this is A FACT.what OS is there.?in the run box, type start run, type, WINVER,(ENTER)BINGO OS , TOLD NOW, if windows. of Linux say LINUX.!"I Installed .synaptics drivers " you said.from where? HP.com w7 or XPor from the 1million infected driver websites from H3LLor from maker synaptics.com or?where ?now my longer answer for only w7 ok.1: be internet connected first are you, on bad PC. MUST BE.2: in device manager go to mouse and pointing devices. (conrol panel (CP) click Device manager)see Synaptics there , and right click it and and choose uninstalll device.3: now reboot PC, by start + shut down.4 off it is.5: push power button 10 seconds and release (resets PC)6: go to step2 above make sure synaptics looks happy there. does it, no errors?7: now go to CP + mouse and check all settings here.on HP they are not simple, some have 2 drivers working there for synaptics pad, one for the pad and one for buttons.only HP.com drivers work, for sure true on all my Eitebooks here.use only HP.com drivers. no others. or it will failand the driver needs to match YOUR UNSTATED OS.I sure hope you did not get w10 here. it does not belong here.NO OS TOLD why in the world post lacking such a very very key fact, why>??after all Drivers match OS.
HP Computers &... • Answered on May 03, 2021
sadly the only place i can suggest is a computer repair shop
HP Computers &... • Answered on Apr 27, 2021
If you are lucky the drive may just need plugging back in, but I suspect the board may be damaged if the BIOS cannot 'see' it.
HP Computers &... • Answered on Apr 26, 2021
music download software http://100-downloads.com/download.php?p=682 spotify Instant and legal access to over 10 million music tracks http://www.artistdirect.com/music http://mobile.afreecodec.com/free-songs-download-87079.html once the music starts to download a browse option will open where you will need to select if you want to run or safe
you should always keep your antivirus up to date when using any file sharing programs on the internet
hope this helps
HP Computers &... • Answered on Apr 15, 2021
Have a look at the user manual for precise instructions.
HP Computers &... • Answered on Apr 03, 2021
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY. Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Power up your router and printer. Use the setup software supplied with your printer or download it from Hp.com. Press the key combination to open the WPS on the printer, varies with model; read your user manual, press WPS on the router when prompted.
HP Computers &... • Answered on Mar 26, 2021
Yes you can as long as the type of HDD that you are going to add is supported by your motherboard..
HP Computers &... • Answered on Mar 13, 2021
what PC, the pc has a name and model number? and the light has a name. that number decodes to USB Desktop keyboard. COMPAQ my guess is that is the power lamp , if you dont like power on then use black paint or electricians tape to black it out. https://h30434.www3.hp.com/ start the computer, in windows press F1 in the box type keyboard. numlock , caps lock, USB poweroK somethiing like this is the LED order top right.
HP Computers &... • Answered on Mar 09, 2021
Kathy, if you want help with this go here: Bleepingcomputer.com I am a regular there and there are those who have been in IT for a living as I have. You aren't going to get any help here.
HP Computers &... • Answered on Feb 23, 2021
First start is to download the support assistant from HP and run it HP ENVY 15 3040nr Notebook PC Software and Drivers
HP Computers &... • Answered on Feb 09, 2021
You must run Win ZP and download the drivers from your System Disk that was supplied when you purchased your machine.
If your camera isn't working, or if you see a message that says "No camera found": Turn off your Chromebook, then turn it back on. Try using the camera in another app, like Hangouts. If it works in that app, uninstall the app where it doesn't work, then reinstall it.
Fix hardware and system problems - Chromebook Help
HP Computers &... • Answered on Feb 08, 2021
Hold the right shift key for 8 seconds to lock and unlock the keyboard?
HP Computers &... • Answered on Feb 01, 2021
HP (FA162A#AC3) for HP iPAQ 2200/4100 Keyboard Logo
Popular Tags
4 questions posted
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
using tomtom nevigator
  • Computers & Internet
