20 Most Recent Fellowes Powershred PS-12Cs, 12 Sheet Cross-Cut SafeSense Shredder Questions & Answers
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then: 1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder. 2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation. 3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder. If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
6/28/2014 3:11:04 PM • Fellowes... • Answered on Jun 28, 2014
2answers
Can I run goo gone through my paper shredder to clean stickiness without dismantling it?
Yes you can, you can also spray it with WD40, leave it an hour, spray it again and run a few sheets of plain paper through it. WD40 is kerosene based.
11/15/2022 2:26:17 AM • Fellowes Office... • Answered on Nov 15, 2022
Powershred 99Ci. Does it have a reset button?
No, but there is an interlock that ensures the collection bin is fully inserted. https://assets.fellowes.com/manuals/99Ci_409366%20090215%20FS%201L.pdf
12/31/2020 5:19:00 PM • Fellowes Office... • Answered on Dec 31, 2020
Our Fellowes C480 will not pull the paper in to shred. The motor runs and sounds normal, but the paper doesn't feed in. Any suggestions?
More than likely your gear is stripped. Depending on what you paid for it it might not be worthwhile.
9/2/2019 7:53:25 PM • Fellowes Office... • Answered on Sep 02, 2019
2answers
Can i get a replacement gear for my fellowes p-45c shredder?
https://www.getthatpart.com/fellowes-p-45c-paper-shredder-oem-39-tooth-second-stage-drive-gear.html
8/13/2019 6:17:07 PM • Fellowes Office... • Answered on Aug 13, 2019
Can i get a manual for a Fellowes PS 72c5 ?
You can find a free manual for it here: https://www.fellowes.com/us/en/support/manuals-downloads.aspx
4/19/2019 8:32:48 AM • Fellowes Office... • Answered on Apr 19, 2019
Fellowes Powershred PS-12Cs, 12 Sheet Cross-Cut SafeSense Shredder Logo
1 questions posted
Top Fellowes Office Equipment & Supplies Experts
David Shaub
George Mclaughlin
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Fellowes Office Equipment & Supplies
Most Popular Question
get top off clear paper jam fellowes ps
  • Office Equipment & Supplies
