20 Most Recent
Smith Corona Wordsmith 250 Electronic Display Typewriter Questions & Answers
Printer head will not return
It may be that the bar that runs across the machine needs a LITTLE oil rubbed on with a cloth, a bad return motor or a bad contact at the return button
Smith Corona XD 5500 - cant make work buttons except a few
If your Smith Corona XD 5500 typewriter is only producing specific characters and some buttons are not working, there are a few potential issues you can investigate:
- Check for Stuck Keys: Make sure none of the keys are physically stuck or jammed. Press each key to see if they respond properly and if any are consistently stuck in the down position.
- Clean the Typewriter Mechanism: Over time, typewriters can accumulate dust, debris, or dried ink, which may impede the movement of keys. Use compressed air to blow out any dust and try to clean the typewriter mechanism.
- Inspect the Ribbon and Correction Tape: Check the typewriter ribbon and correction tape. If the ribbon is improperly installed or the correction tape is stuck, it can affect the functioning of the keys. Ensure that the ribbon and correction tape are correctly threaded.
- Check for Mechanical Issues: Inspect the internal components for any visible signs of damage or misalignment. Ensure that all the moving parts are functioning smoothly. If you notice any broken or misaligned parts, you may need to seek professional repair.
- Verify the Keyboard Switch: Some typewriters have a switch to toggle between different character sets or functions. Check the user manual for your specific model to see if there's a switch that might be affecting the keyboard.
- Test the Typewriter in Manual Mode: Most typewriters have a manual mode where you can type without the ribbon or correction tape engaged. Test the typewriter in manual mode to see if the issue persists. This can help determine if the problem is related to the typing mechanism or the printing elements.
- Consult the User Manual: Refer to the user manual for your Smith Corona XD 5500 for troubleshooting tips and information about the specific features of your typewriter.
- Professional Repair: If the issue persists and you're unable to identify or resolve the problem, it may be necessary to seek professional repair. Contact a typewriter repair specialist or a local office equipment repair service for assistance.
Remember that working with vintage typewriters may require specialized knowledge, and attempting to disassemble the typewriter without proper expertise can lead to further damage. If in doubt, it's advisable to seek professional assistance for repairs.
Smith Corona se100 print head travels to extreme left, buzzes then powers down.
It sounds like there may be an issue with the print head carriage on your Smith Corona SE100 typewriter. Here are some steps you can take to troubleshoot the issue:
- Check for any obstructions: Make sure that there are no obstructions blocking the print head carriage from moving freely. If there are any obstructions, remove them carefully.
- Clean the print head carriage: Use a soft, dry cloth to wipe the print head carriage and ensure it is clean and free of any dust or debris.
- Check the power supply: Make sure that the typewriter is properly plugged in and receiving power. Check the power cord and outlet for any issues.
- Try resetting the typewriter: Turn off the typewriter and unplug it from the power source for a few minutes. Then, plug it back in and turn it on again to see if the issue has resolved.
If none of these steps resolve the issue, it may be a more serious issue with the print head carriage or other internal components. In that case, it may be best to take the typewriter to a professional repair shop or contact the manufacturer for assistance.
Smith corona DeVille 650
Take the ribbon off and see if the driven spool turns? It is does, replace the ribbon with a new one. If it doesn't you need service.
