20 Most Recent Smith Corona SD700 Electronic Typewriter Spell-Right Questions & Answers
Turn the keyboard on using the Kb button. memory lost may be a bad battery that is no longer available.
Smith Corona... | Answered on Feb 02, 2017
Brand new? Contact the seller and/or manufacturer about the warranty. https://www.smithcorona.com/
Is this the machine? https://www.amazon.com/Smith-corona-Coronamatic-Portable-Electric-Typewriter/dp/B0112YFSFE
Anyway, if the keys type and the ink isn't showing, the problem seems to be with the ribbon. If it is not advancing, the keys hit the same spot repeatedly, no ink. If it is advancing, there may be a
control that modifies the striking power of the keys and that might be adjusted. If it is not a matter of striking power, perhaps the ribbon was not installed properly or simply was dried out. https://www.youtube.com/watch?v=CF0rskT16jQ
As to the space bar not working, that probably requires some disassembly. Here is a page describing the general problem: https://www.instructables.com/Easy-Spacebar-Repair/
Here is a page for disassembly: https://www.youtube.com/watch?v=UVLDvPdgebU
However, this could easily turn into a fiasco of the type where someone opens up a watch and thinks they can repair it. They don't have the tools nor the technical skills. That's reason enough to call the manufacturer for warranty info and/or support.
Smith Corona... | Answered on Oct 14, 2020
Vendors that display a copy of the manual in their ads might be contacted to request a copy of the manual.
Example:
https://www.amazon.com/Smith-Corona-DeVille-470-Correctable/dp/B003TZBMX2
Smith Corona... | Answered on Jun 15, 2020
Remove print wheel...clean with soapy water
Smith Corona... | Answered on Jan 27, 2020
Most likely bad printwheel, spokes may be catching on the ribbon and not going to home position. Try a new wheel, and or make sure carrier is returning to home position every time. make with white out the top of the print wheel spoke at home position and make sure it always comes back to that spot when you turn machine on and off and on. This will tell you if the machine is starting in the same place every time.
Smith Corona... | Answered on Mar 25, 2019
What happens, any noise, etc. some times the chrome rail
inside the machine gets sticky and will not let the carrier move. Also if you hit the carriage return key and nothing happens, my be bad keys or keyboard...
Possible bad wheel or spooks are bent and not going to home position. Look at wheel
Smith Corona... | Answered on Feb 22, 2019
Smith Corona SD700 Electronic Typewriter Spell-Right Logo
2 questions posted
Top Smith Corona Office Equipment & Supplies Experts
James Keysor
Level 1 Expert
STEVE SPAM REMOVER
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Smith Corona Office Equipment & Supplies
Most Popular Question
memory typewriter smith corona sd700
  • Office Equipment & Supplies
