20 Most Recent HP Officejet 6700 Premium E-All-In-One Questions & Answers
HP Officejet 6700 Premium Missing or Failed Printhead Error Message
Many people mention this problem and had trouble like you at the discussion link above.
HP Officejet... | Answered on Jan 27, 2019
Are you getting a scanner failure error? Turn the printer off, open the scanner cover and turn printer on and see if the scanner moves or the light comes on. If it does not then likely the scanner has failed.
HP Officejet... | Answered on Jan 24, 2016
If you have the CD that came with the printer, you can reinstall from that. If not go to HP.com and select the SUPPORT tab, and select the DRIVERS option on the drop-down menu. When the page appears, you can use the manual selection option, or if the printer is attached to the device you are using to access the site, you can try the auto detection process. Once you get to the download, choose the driver for the OS you have. Then download and install it.
HP Officejet... | Answered on Oct 22, 2015
You need to talk to HP tech support... to do a proper reset you need to access menus that are meant for tech support and developers only. If you "brick" your OJ using those menus on your own (including instructions from anyone here), it's considered customer damage and voids the warranty. If you post your request at the link below, you should get a PM from an official HP tech support person telling you how to do the reset.
Officejet 6700 premium won pick up faxes
HP Officejet... | Answered on Mar 08, 2015
Please clean the contacts on the back of the cartridge with soft tissue and some ethanol. Also check if contacts are not damaged.
HP Officejet... | Answered on Feb 09, 2015
Maybe someone is using the line to make a call, verify that your handset is in the correct position
HP Officejet... | Answered on May 29, 2014
If you read through the posts, there are many ideas on what to do. The cheapest and easiest way I found to fix a broken hinge is to follow one the ideas in the posts. I wrote a detailed post step-by-step. In quick summary, I broke the other hinge and removed all the broken pieces to both, so the lid would lay flat again. Printer doesn't care if the hinges are not there. The manual is on line:http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3635378 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
HP Officejet... | Answered on Apr 01, 2014
!Ahh, this is a little tricky but I have found the best way is to wait until after normal business hours so the printer is not expecting anything.
Then sneak around behind the printer and throw a blanket over it so that I can't see whats happening, open the ink tray and remove the empty cartridge while getting out an original ink cartridge box.
This is the trick - Secretly put the refill in place of the expended original cartridge!
As you pull the blanket (or whatever you surprised your printer with) off the printer, walk away muttering how expensive printer ink is and throw the empty original cartridge in the rubbish.
Your printer should now be completely fooled into thinking it has a new original cartridge!
HP Officejet... | Answered on Feb 28, 2014
What this will most likely is a driver issue, what I suggest is check what driver you are using.
to do so go to start then devices and printers
right click your printer and go "Printer Properties" in the new window click on the advanced tab you should see the option for a new driver and the one It is currently using. if it is using a generic windows driver try swapping to a HP official driver from their website. if it still doesn't work you could try one of the universal drivers.
HP Officejet... | Answered on Dec 13, 2013
Have you replaced the USB cable?
HP Officejet... | Answered on Dec 12, 2013
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
HP Officejet... | Answered on Sep 20, 2012
HP Officejet 6700 Premium E-All-In-One Logo
45 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
hp 6700 printer change ink cartridge
  • Office Equipment & Supplies
