20 Most Recent Tylo Super Sport 7 Sauna Heater Questions & Answers
On top of the unit/sauna, you will need to remove the roof or wood covering. It is held down with screws, usually. If your unit in fact does have a reset it will be located on the side of the control box which is located on top of the sauna.
Tylo Super Sport... | Answered on Nov 23, 2017
Remove weights, Thoroughly clean cleaner, backwash filter system to get optimum suction. Check filter system for optimal suction..., ie. leaks, excess debris, clogged baskets, strainers, etc..
Pool & Spa | Answered on Jan 12, 2021
in the economy mode it will only maintain a temperature so that it will not freeze. Economy mode is mostly for vacation time or for winter if you are not going to be using the hot tub for an extended period of time.
Put it into the standard mode and you will be able to have a HOT tub and will function as it should
US Parts Center
Pool & Spa | Answered on Dec 27, 2020
We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Pool & Spa | Answered on Dec 15, 2020
If you can see air swirling around, then there's bound to be water moving around. Otherwise you wouldn't see anything moving. You have a small suction leak somewhere. When you don't have the heater turned on, there's less strain on the pump and therefore less of a suction leak. Assuming your heater has an auto-bypass. Use your garden hose to find the suction leak and patch with silicone or pool putty. Or replace o-rings and gaskets. Check plugs and grease ports, etc.
Pool & Spa | Answered on Nov 25, 2020
check and test air pump --look up on internet for multi-sites that show how to test
Pool & Spa | Answered on Nov 21, 2020
Hi Don.
See if this link helps you out. https://nymag.com/strategist/article/best-alkaline-water-machines-filters.htmlps you out.
Pool & Spa | Answered on Nov 19, 2020
Failure of the older heating system
Pool & Spa | Answered on Nov 17, 2020
Tylo Super Sport 7 Sauna Heater Logo
2 questions posted
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Tylo Pool & Spa
  • Tylo Pool & Spa
Most Popular Question
safety shutoff tylo super sport 7
  • Pool & Spa
