20 Most Recent Stihl Ts410 & Ts420 Cylinder & Piston Kit Questions & Answers
Starting procedure for Stihl.
(cold starting)
Place cutoff saw on floor (flat clear surface).
Hold throttle in, while pushing on switch all the way down.
Hold cutoff saw firmly.
Pull starter handle until saw fires, it should then cut out.
Click the starter switch up 1 click to half choke.
Pull starter handle again until cutoff saw fires up. note: it will be reving because the trigger is loched on, (blip the throttle once) and it should go to tick over.
There should be np need to keep playing with the choke when the saw is warm. No need to lock the trigger when starting warm..
Stihl Ts410 &... | Answered on Mar 31, 2013
Elaborate, "rebuilt"?
Check if flooded. Remove sparkplug and give the the recoil start several pulls to clear cylinder. If plug is wet, dry with compressed air or spray off with starter fluid.
Reinstall plug and try starting without choke.
Stihl Garden | Answered Yesterday
https://www.stihlusa.com/webcontent/cmsfilelibrary/instructionmanuals/stihl-ts-510-760-owners-instruction-manual.pdf
Stihl Garden | Answered on Jan 13, 2021
There is no absolute requirement to use Stihl fuel though they claim better results, something lots of users agree with.
I suggest you read the manual again to ensure you have exactly followed the instructions. If you did and it won't work there is cause to return it to the dealer. While an older machine often needs fiddling with a new machine should not.
One thought - if the dealer's demonstration was very short so the machine did not warm up thoroughly, it is possible that fouled the spark plug and that would serve to make restarting difficult. It would be wise to check the plug and ensure the spark is ok...
Stihl Garden | Answered on Aug 14, 2020
Yes it is commercial blower
Stihl Garden | Answered on Apr 30, 2020
One wire is ignition module kill (primary of a magneto) and the other is ignition module frame (engine block).
The two wires run separate to the kill switch which is a momentary single pole.
Stihl Garden | Answered on Apr 24, 2020
start with a tune up and a carb rebuild test cdi and clean as well
Stihl Garden | Answered on Apr 07, 2020
More likely the starter recoil is binding.
Stihl Garden | Answered on Mar 19, 2020
Chec utube or buya clymer manual ...gottools
Stihl Garden | Answered on Jan 13, 2020
make sure your air gap from the coil to the flywheel magnet is .010. if it is then take the ground wire off the coil and see if you have spark then. if you do then your ground wire is grounding out somewhere. process of elimination form the coil to the switch.
Stihl Garden | Answered on Dec 28, 2019
Possibly fuel tank not venting properly. See recall.
https://www.stihlusa.com/information/recalls/toolless-fuel-cap/km130r/
Stihl Garden | Answered on Dec 14, 2019
Numerous women question how they could shrink fibroids naturally in the estimate to either steer clear of surgery or to fibroids home treatment cozy by themselves.
Stihl Garden | Answered on Dec 05, 2019
Set the gap between coil and flywheel to 0.010 inches, if possible disconnect the stop wire from coil to eliminate that part of the circuit. If spark, reconnect stop wire and check again with stop switch in the on position, should still have spark. If not there is a short in the stop circuit.
Stihl Garden | Answered on Oct 31, 2019
According to Stihl's engine service manuals, when the engine has no spark or a dramatic, sudden loss in power, the problem could lie in the ignition system. The ignition system ignites the fuel in the engine for proper combustion. When the spark isn't firing correctly, an influx of gas can bog the engine down or cause it to not start at all. Since you are dealing with potentially lethal high voltage, extreme caution is advised and safety gear should be worn at all times.
first Slide the rubber spark plug connector off of the spark plug. On most Stihl's this can be accessed from the top of the engine, underneath the chain brake handle. Unscrew the air filter cover and remove it, if you can't see it on top of the engine
then Insert the socket wrench onto the spark plug and remove it from the engine. Discard the old spark plug and replace it with a new, identical spark plug, which will be recommended in your operator's manual. Make sure the spark plug is gapped according to your manual's specifications or else the engine won't start.
after that Turn the ignition switch to the "On" position. Insert the spark plug into the rubber connector. Make sure the chain brake is disengaged by pulling back on the black chain brake handle, which runs atop the saw's engine.
Hold the rubber plug and spark plug, with gloved hands, about 1 to 2 centimeters from a metal point on the engine block. Wipe any flammable gas or oil from the metal spot on the engine with the rag. Tug on the starter cord and look for a blue spark across the "hex" part of the spark plug,Check to be sure the wires leading to the "On-Off" switch aren't tangled or touching a metal point on the engine if there is no spark, Replace any wires if they are damaged or corroded
Stihl Garden | Answered on Oct 30, 2019
Check the ground wire on your coil and see if it is loose or well grounded...
Stihl Garden | Answered on Oct 29, 2019
Stihl Ts410 & Ts420 Cylinder & Piston Kit Logo
Popular Tags
2 questions posted
Top Stihl Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
bryan st
Are you a Stihl Garden Expert? Answer questions, earn points and help others
View Most Popular
Stihl Garden
  • Stihl Garden
Most Popular Question
ts410 stihl saw stopped working
  • Garden
