20 Most Recent Turbo Air M3R72-3 - Reach-In Refrigerator w/ 3-Section & Solid Full Do Questions & Answers
My turbo air pizza prep 3 door fridge is doing horrible thing as it's temperature getting 31 and plus... what to do?
I think the best thing fir you to do is to call a technician to come check it out for you so you don’t worsen things
10/6/2022 10:48:39 AM • Turbo Air... • Answered on Oct 06, 2022
2answers
I have a turbo air freezer it will turn on an hit temp then turn off after that the compressor will turn on and off for only for a few seconds. If I unplug it and leave it set awhile it will run.
Thermostat. An incorrectly adjusted thermostat can cause the freezer's compressor to start and kick off. ... The inside temperature of the freezer determines when the thermostat sends the signal to power the compressor. Set the thermostat to a lower setting to see if the compressor starts and then stays on.
1/14/2021 2:38:05 PM • Turbo Air... • Answered on Jan 14, 2021
Turbo air freezer m3 f72 cools ok but will not stop cooling set to highest temperature , shows 10 deg F and keeps cooling
If it is a freezer, it should reach at least 0 degrees before turning off. I sounds like a thermostat issue. I would look at that first since it is set on it's highest setting and not shutting down. Thanks
5/22/2020 10:03:33 PM • Turbo Air... • Answered on May 22, 2020
Turbo air freezer M3 does not stop cooling shows 0 deg set to highest setting I have replaced control board
Fridge/freezer freezing up-and no fanor air circulation: first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice.? AT TIMES The fan usually stops workingAND CAN MAKE FUNNY NOISES AS WELLdue to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check thedefrost timer,The defrost timer is usually found behind the front grill "toe kick" of the refrigerator.Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engageurdefrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providingurterminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Placeurmeter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Takeurmeter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Nowur1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u knowurtimer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is theheating elementitself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check thecold control thermostatwith a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEMand THERMISTORSAt times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being putout. In most models around 1300( give or take 150 ohms) ohms is required https://www.youtube.com/watch?v=zmdsBkO46dk defrost therm.
3/12/2020 10:14:12 PM • Turbo Air... • Answered on Mar 12, 2020
I have a Turbo Air TGF-9F, a single compartment top slide freezer. Picture a rectangle, the right side keeps frozen (frost on the walls) and left is room temp not trying to get cold. Any Solutions?
Could be blocked by ice formation. Leave switched off for a few hours with the door open to allow to defrost.
5/17/2019 6:59:53 PM • Turbo Air... • Answered on May 17, 2019
Turbo Air Model TGF-23F Wont get cold. Compressor comes on and runs but evaporator fan isn't running.
Yes everything get power from the board. Look for wiring diagram and trace wire out
7/27/2018 2:21:39 PM • Turbo Air... • Answered on Jul 27, 2018
Turbo air maximum ref MSR-49NM goes to minus freezing temps everything has been cleaned unplugged for 24 hours. worked for 2 weeks went to minus temps again last night
In generic terms, it is either the temperature controller or the sensor that reads the temp and sends that to the controller. Something is no telling the compressor to turn off.
2/16/2018 2:16:27 AM • Turbo Air... • Answered on Feb 16, 2018
M3 turbo air freezer. M3F24-1 temp on display is not temp of box
this could be a bad temp sensor or lack of proper air flow. Make sure the evap fan runs when it's supposed to be running. Also make sure the evap is not freezing up. all these items can cause what you are describing.
7/28/2017 2:22:29 AM • Turbo Air... • Answered on Jul 28, 2017
0answers
Turbo Air M3R72-3 - Reach-In Refrigerator w/ 3-Section & Solid Full Do Logo
0 questions posted
Top Turbo Air Refrigerators Experts
john h
Jorgie  the...
Jorgie the...
David Spradling
David Spradling
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Turbo Air Refrigerators
Most Popular Question
turbo air commercial food preparation
  • Refrigerators
