20 Most Recent Honda 2012 - Odyssey Questions & Answers
CODE B13 WHAT IS IT TELLING ME?????? 2012 honda odyssey touring
look in the manual under maintenance minder i believe. you match the Letter and the Number(s). (B) Replace engine oil and oil filter Inspect front and rear brakes Check parking brakeadjustment Inspect these items: Tie rod ends, steering gear box, and boots Suspension components Driveshaftboots Brake hoses and lines (including ABS) All fluid levels and condition of fluids Exhaust system Fuel lines and connections (1) Rotate tires (3) Replace transmission fluid Driving in mountainous areas at very low vehicle> speeds or trailer towing results in higher transmission temperatures. This requires transmission fluidchanges more frequently than recommended by the Maintenance Minder. If you regularly drive your vehicle under these conditions, have the transmission fluidchanged every 30,000 miles (48,000 km). Honda Odyssey Forum Odyssey Minivan Forums
2/22/2015 11:57:09 PM • Honda 2012 -... • Answered on Feb 22, 2015
Find a radio code
Did you pull out the radio. It might have the code on the radio
12/9/2014 1:06:44 AM • Honda 2012 -... • Answered on Dec 09, 2014
2answers
Honda GXV340 small engine. I am trying to find out what my Honda GXV340 engine ignition coil air gap is please?
Question edited for better English.
Technical Information
Multiquip https://service.multiquip.com > pdfs > Honda_G... PDF May 26, 2010 - Technicians will need to check the air gap between the ignition coil and flywheel during service inspections or after replacing the coil.
Honda Small Engine Ignition Armature Air Gaps
Outdoor Power Equipment Information https://outdoorpowerinfo.com > honda_fly_gap The amount of clearance between the flywheel magnets and the ignition armature. The ignition armature is also referred to as ignition module, coil, laminate, ...
2/23/2024 2:03:15 AM • Honda Garden • Answered on Feb 23, 2024
3answers
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
11/6/2023 11:14:28 AM • Honda Garden • Answered on Nov 06, 2023
Honda mower model HRR2163VXA engage blade and it backward not engage
If your Honda mower model HRR2163VXA is not engaging the blade properly when you attempt to engage it, and it's moving backward instead, there could be a few potential causes for this issue. Here are some steps you can take to troubleshoot and address the problem:
  1. Safety Interlock System: Most modern lawn mowers, including Honda models, are equipped with safety interlock systems that prevent the blade from engaging while the mower is in reverse or the handle is not properly engaged. Make sure you are following the correct procedure for engaging the blade and that you are not inadvertently activating the safety mechanisms.
  2. Drive Control Lever Position: Check the position of the drive control lever or drive engagement lever on your mower. Ensure that it is in the proper position for mowing and not in a neutral or reverse position.
  3. Control Cable Adjustment: The control cables that operate the blade engagement and drive functions can sometimes become loose or misadjusted. Check the cables for proper tension and ensure they are connected securely to their respective control levers.
  4. Belt and Pulley Inspection: Inspect the belt that drives the blade engagement system for any signs of damage or wear. Additionally, check the pulleys and pulley mechanisms to ensure they are functioning properly.
  5. Blade Engagement Mechanism Inspection: Examine the blade engagement mechanism itself, including the engagement lever and associated components. Look for any signs of damage, wear, or misalignment that could be preventing proper engagement.
  6. Consult the Manual: Refer to the user manual for your Honda mower for specific instructions on troubleshooting and adjusting the blade engagement system. The manual may have diagrams and step-by-step instructions for resolving issues.
  7. Professional Assistance: If you're unable to identify and resolve the issue on your own, consider seeking assistance from a professional lawn mower technician. They will have experience with Honda mowers and can diagnose and repair any mechanical or electrical problems.
It's important to prioritize safety when working with lawn mowers. If you're unsure about any step or if the issue is not easily resolved, it's recommended to seek professional assistance to avoid potential injury or further damage to the equipment.
8/5/2023 10:23:41 AM • Honda Garden • Answered on Aug 05, 2023
Blades spin but not fast enough to cut grass, can hear them slowing and then they start chugging. Deck at full height and belt is not too loose (adjusted to max tightness)
Do the engine rpms drop or only the blade speed?
If belt is tight at cutting height and engine rpms hold, then the vbelt from engine to deck is likely is dry burnished or oily.
First check the blades are install cutting edge down (fin up). If belt from engine to deck has a glassy finish (burnished) replace belt or remove burnish with sandpaper.
It appears be relatively complicated deck system. See owners manual regarding deck remove/install.
https://www.manualslib.com/manual/1205115/Honda-Hf2622.html?page=20
6/6/2023 10:58:32 PM • Honda Garden • Answered on Jun 06, 2023
3answers
Service manual for Honda g200 engine
Hello, the manual you requested can be downloaded at the following link:
http://engines.honda.com/parts-and-support/owners-manuals/g200
Hope this is what you have beel looking for.
5/23/2023 8:06:09 AM • Honda Garden • Answered on May 23, 2023
Can the pull cord be replaced on a Honda HRH536 or do you have to buy a new whole assembly?
The cord is listed as a separate item and there are numerous online how to videos of similar Honda products/engines.
Problems you may run into are, if the recoil spring is broken and the cord does not retract, it may be better to replace the assembly. Or if the cord has already snapped in which case it will be necessary to preload the spring.
4/29/2023 8:17:20 PM • Honda Garden • Answered on Apr 29, 2023
4answers
A 2.3 Honda outboard the vent in the gas cap won't allow enough air in. Run for 4 min it quits. Run with the gas cap loose it runs fine. How do I fix it?
Well, replace the cap. Try cleaning the vent in the cap with a small wire.
4/16/2023 2:59:48 AM • Honda Garden • Answered on Apr 16, 2023
Honda GCV160 engine Pressure Washer. The pull cord locked up.
Question edited for clarity. You need to remove the pull cod mechanism as if you were replacing it. You will normally find the cord has moved out of its track. it is also possible that the spring broke and locked up.
4/13/2023 9:11:52 PM • Honda Garden • Answered on Apr 13, 2023
My Honda gx 240 8hp has gas in the oil
Carburetor float or needle valve not functioning properly. Remove carburetor bowl and assess.
2/22/2023 2:18:56 AM • Honda Garden • Answered on Feb 22, 2023
Spark plug torque for a Honda GX390
spark plugs 15-21 ft. lbs.
12/18/2022 12:51:20 PM • Honda Garden • Answered on Dec 18, 2022
Spark plug torque Honda GX390
A common setting is 20 to 30 Nm, (15 to 20ft/lbs). First fit the spark plug with your fingers until tight. This is to make sure the screw thread lines up correctly. Then using a socket and extension bar like a screwdriver tighten the spark plug again. Finally, using the torque wrench set to 21Nm (15 ft/lbs), slowly tighten the spark plug until it is just getting tight or the wrench clicks. **DO NOT over-tighten the spark plug as stripping the screw thread can be an expensive mistake.**
12/18/2022 12:49:37 PM • Honda Garden • Answered on Dec 18, 2022
Does a Honda GCV 190 engine used on pressure washer have an idler screw or how do I idle it. Runs fine but when I let off the trigger it goes dead. Thank you.
https://duckduckgo.com/?t=ffab&q=Honda+GCV+190+engine+idler+screw&atb=v159-1&iax=images&ia=images&iai=https%3A%2F%2Fwww.outdoorking.com%2Fforum%2Fuploads%2Fusergals%2F2013%2F08%2Ffull-2772-12005-honda_gcv160_idle_speed_adjustment.png
12/16/2022 9:36:00 PM • Honda Garden • Answered on Dec 16, 2022
Getting my honda gc 190 to use the soap out of the plastic container
Soap Injector Not Working Properly When a soap injector is not working properly, the problem is generally fairly easy to isolate. Check the following: 1. If you have interchangeable tips, make sure the Black, soap tip is installed. Soap injectors will not work when high pressure nozzles are installed. 2. Be sure that the soap injector valve is turned on, and turn selector valve to desired setting. 3. A piece of debris may be caught in the injector valve, injector ball valve, or orifice. Disassemble and clean the injector. 4. If you have an adjustable nozzle, be sure it is in the low pressure position (away from the gun) to draw soap. Interchangeable Tips Your machine is supplied with either interchangeable tips or a multi-reg. Your machine is supplied with interchangeable spray tips. The black tip lowers your pressure and draws chemical. The other tips are for high pressure rinse at different spray angles. Red is 0 degree, yellow is 15 degree, green is 25 degree and white is 40 degree. The yellow tip is used for most standard applications. Be sure the quick coupler is fully engaged before pulling the trigger gun. Failure to do may result in the tip becoming a projectile and may be lost or damage to property or persons may occur.
10/20/2022 10:09:25 AM • Honda Garden • Answered on Oct 20, 2022
2answers
Riding mower sounds like rock clanking around when PTO engaged
possible mandrel damage or blade is bent
10/19/2022 3:33:38 AM • Honda Garden • Answered on Oct 19, 2022
Honda 2012 - Odyssey Logo
4 questions posted
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
View Most Popular
Honda Garden
  • Honda Garden
Most Popular Question
code b13 telling me 2012 honda
  • Garden
