20 Most Recent Samsung ST-200 16 Megapixel Digital Camera Plum Questions & Answers
It is detecting it has enough light and not flashing. Look for an "indoor" or other appropriate mode for what you are shooting since most Samsung cameras have them. The flash will only go off when the camera thinks it is needed. Canon Cameras are useless indoors but Samsung's are pretty good indoors when you find the right setting. Their latest models have dozens of modes, most of which you will never use. They are just VERY slow to take pictures. It appears to be cheaper version of their WB250F I had for a while.
P.S. - Never drop a Sansung camera. They will chip and even get damaged from as little as a foot or so. I had one fall about a foot onto pavement and it was permanently ruined. Their older models also stop with lens out when the battery dies but the Galaxy Cam is finally smart enough to retract the lens before the battery dies. It alos does so when shutting down unlike the older models.
Samsung ST-200... | Answered on Apr 16, 2015
Most likely the switch is bad and has failed in the full on position. I would start by replacing the switch or you might just swap it with another working switch on the stove and see if it does the same thing or if it works properly.
Samsung Kitchen... | Answered 3 days ago
C-31 is caused by an overheated PCB. The solution is to call for service.
Samsung Kitchen... | Answered on Jan 06, 2020
an F error code.
You have a function error code.
CODECAUSE
-SE-Shorted key
E-27Oven sensor opened
E-28Oven sensor shorted
E-08Oven heating error
E-0AOven heating over
E-0EDoor locking error
• Press the CLEAR/OFF pad and restart
the oven. If the problem persists,
disconnect all power to the range for at
least 30 seconds and then reconnect the
power. If this does not solve the problem,
call for service.
The surface units
will not maintain
a rolling boil or
will not cook fast
enough.
Improper cookware is being
Samsung Kitchen... | Answered on Sep 23, 2019
This is the belt number:
SAMSUNG FRONT LOADER DRIVE BELT 6602-001072 (1050323)
And this is just one source for the belt:
http://cgi.ebay.co.uk/SAMSUNG-FRONT-LOADER-DRIVE-BELT-6602-001072-1050323-/250632182892
Thanks for choosing FixYa,
Kelly
Samsung Kitchen... | Answered on Sep 17, 2019
Coincidences do happen - your ride-on mower was probably one of those but the pattern of electrical problems you have experienced lately does suggest a common fault with your supply.
Could be your house is receiving power surges and maybe you haven't enough surge protection. Perhaps your system ground isn't very good.
One woman that posted here a few months ago was wondering why certain electronics kept breaking. It turned out a gas pipe wasn't grounded and gas flowing through the pipe caused a static electricity charge to build in the pipe until it jumped to whatever was nearby.
You need to consider almost everything these days contains a computer of some sort and so breaks much easier than older appliances, though in fairness appliances today do have a built-in limited life.
Samsung Kitchen... | Answered on Aug 05, 2019
loose connection or failing they dont give error codes for them
Samsung Kitchen... | Answered on Jun 02, 2019
power of for sum tine and then power on...
Samsung Kitchen... | Answered on May 16, 2019
Samsung ST-200 16 Megapixel Digital Camera Plum Logo
1 questions posted
Top Samsung Kitchen Ranges Experts
Marvin
Marvin
Vernon Taylor
Roy Cunningham
Level 1 Expert
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Kitchen Ranges
Most Popular Question
flash doesnt work flash icon shows
  • Kitchen Ranges
