20 Most Recent LG LFX25974ST 24.7 cu. ft. French Door Refrigerator With Freezer Light Questions & Answers
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
LG LFX25974ST... | Answered on Aug 07, 2020
replace the icemaker timer . thanks .
LG LFX25974ST... | Answered on Mar 05, 2016
Check for a bad hard start cap/relay on compressor. If it is running check for ice on evaporator - if ice then the defrost mechanism is not working.
LG Refrigerators | Answered on Oct 14, 2020
LG brand
switch off at the wall point
wait a bit
start again
if its not in the user manual and no one can figure out why
if it still beeps some part of that unit has failed or needs to be reset
no other choice but to call out a lg repair man
LG Refrigerators | Answered on Sep 27, 2020
Could be the hinge, most likely the lower hinge. Fridge hinges usually have a plastic insert in the door to prevent metal to metal contact. This insert sometimes wears prematurely and then metal may start to make contact , thus the grinding sound. The insert can be changed fairly easily if you are so inclined.
LG Refrigerators | Answered on Sep 19, 2020
The most probable reason is leakage of refrigerant gas. You have to get it refilled and sealed by the mechanic.
LG Refrigerators | Answered on Aug 19, 2020
I did turned it off for like a 10 minutes and it worked my problem was it was beeping and no light but it was cooling
LG Refrigerators | Answered on Aug 07, 2020
Unplug the LG fridge and wait 20 minutes - Plug back into power - Many times the code will clear or reset. If not keep reading below... -The majority of the time it is the freezer fan causing the Er FF error code. The FF error code indicates that the freezer fan motor is defective.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
https://www.lg.com/us/support/help-library/error-codes-refrigerator-CT10000021-1441392048805
LG Refrigerators | Answered on Aug 05, 2020
When the refrigerator and freezer reach the set temp, the blinking stops. – If the blinking does not stop, unplug the refrigerator for about 30 seconds to reset the processor. – If the display still blinks it may indicate a problem within the freezer.
Check the freezer:
If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
LG LFX25974ST 24.7 cu. ft. French Door Refrigerator With Freezer Light Logo
3 questions posted
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
code er co keeps coming display panel
  • Refrigerators
