20 Most Recent LG LFX28978SW - French Door Refrigerator with Ice/Water Dispenser - W Questions & Answers
LG brand
switch off at the wall point
wait a bit
start again
if its not in the user manual and no one can figure out why
if it still beeps some part of that unit has failed or needs to be reset
no other choice but to call out a lg repair man
LG Refrigerators | Answered 2 days ago
The most probable reason is leakage of refrigerant gas. You have to get it refilled and sealed by the mechanic.
LG Refrigerators | Answered on Aug 19, 2020
REPLACE THE AIR DAMPER CONTROL
LG Refrigerators | Answered on Aug 08, 2020
I did turned it off for like a 10 minutes and it worked my problem was it was beeping and no light but it was cooling
LG Refrigerators | Answered on Aug 07, 2020
Unplug the LG fridge and wait 20 minutes - Plug back into power - Many times the code will clear or reset. If not keep reading below... -The majority of the time it is the freezer fan causing the Er FF error code. The FF error code indicates that the freezer fan motor is defective.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
https://www.lg.com/us/support/help-library/error-codes-refrigerator-CT10000021-1441392048805
LG Refrigerators | Answered on Aug 05, 2020
Check the freezer:
If your fridge does not have an auto-defrost function then excessive ice-build up in the freezer can cause the beeping alarm. If you see a lot of ice build-up in the icebox or freezer, switch off the fridge and let the ice thaw. Once the fridge is thawed, the beeping should stop.
Replacing the start relay is just the beginning. Code 22 also indicates there is a mechanical problem that only a technician can solve.
LG LFX28978SW - French Door Refrigerator with Ice/Water Dispenser - W Logo
4 questions posted
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
low volume beep sound every 3 minutes
  • Refrigerators
