20 Most Recent
Samsung RFG297HD 29 Cu. Ft. French Door Refrigerator with Thru-the-Door Ice Questions & Answers
Hi I have a Samsung fridge model DA99-01221D . My freezer is cooling well but fridge is not cooling at all please help
Check the Control Settings:
Ensure that the temperature settings for both the fridge and freezer compartments are appropriately configured. Sometimes incorrect settings can lead to cooling problems.
Make sure the fridge is not in demo mode. If it is, disable demo mode by referring to your user manual.
Inspect the Door Seals:
Damaged or worn-out door seals can cause cold air to leak out, resulting in insufficient cooling in the fridge compartment. Inspect the door seals for any cracks, tears, or gaps.
If you find any issues, consider replacing the door seals.
Evaporator Coil and Fan Check:
The evaporator coils in the fridge play a crucial role in cooling. If they are frozen or malfunctioning, it can affect cooling.
Similarly, check if the fan responsible for distributing cold air inside the fridge is working correctly.
Reset the Refrigerator:
Sometimes a simple reset can resolve cooling issues. Unplug the fridge from the power source for a few minutes, then plug it back in.
Observe if there's any improvement in cooling after the reset.
Compressor Overheating:
You mentioned that the compressor is very hot. An overheated compressor can impact cooling.
Allow the compressor to cool down completely before switching the fridge back on.
4/1/2024 3:42:13 PM •
Samsung...
Answered
on Apr 01, 2024
Fans in both refrigerator and freezer of Samsung RF4287 HARS-xaa are not working. Replaced evaporator fan motor in fridge and it is still not working. Help, please!
could be just the coil on the valve, but most more likely valve getting stuck as it opens. somtimes can take apart and clean, will work for awhile, but if have the cash best just swap it out. will save you hassel down the road.My Aplogies I was under the impression you had already located the valve. I as I have not seen unit I can not give the location, However since it is on the water system, I would trace water tubing from where it connects to unit. It should not be far from inlet connection. Look for tubing going to a valve with wires ontop, ensure after the valve is where you whish water/ice to come out. Once that is located take photo and order new valve, or secure water remove and clean valve. Note have container ready as water will leak once you remove valve.
1/25/2024 4:41:01 PM •
Samsung...
Answered
on Jan 25, 2024
Our Samsung refrigerator model RFG297ACRS is not cooling and freezer not cold.
First I would clean all grim. Second if you do not have refrigerant gauges feel discharge line with hand. Will be a smaller line and coverd with foam. It should be hot to condensor. if not You probabaly lost charge. Also top of compressor should be hot. Should the above not meet specs. You need to find leak, get a pro. to locate repair leak, as you need licenese to go further.
1/24/2024 9:51:02 PM •
Samsung...
Answered
on Jan 24, 2024
Evaporator fan new but not working on samsung rs267lash
Manny MANY unfortunate customers who bought this **** from Samsung have problem.
Specifically the Freezer cold but fridge side no lower than 55deg problem.
It is a known defect that Samsung has not taken ownership
of.
I have the same problem with the same model as many.. if you search the
net.
Iv'e been trying to find a designated website for repairs for this
problem. Please post website with solution if anyone finds it.
Thanks
1/24/2024 8:45:56 PM •
Samsung...
Answered
on Jan 24, 2024
Samsung fridge freezer not freezing properly
First: i don't know. In the manual there should be some pages for solving dysfunction and what the lights mean.
Always check for damage on the closed and pressurized system, including inside, where the tubular radiators are, mostly half within the panels. Those may have broken when using tools to remove ice or been hit rough with some object.
For a right understanding: the fridge must not be shaken or tilted and carried. When this has happened, then the evaporation fluid or refrigerant can be mixed with the oil that resides on the bottom of the compressor. It may only have a small sponge to clear the fluid from a little oil contamination. What finally solves the mixing is shutting the fridge off for 24 hours and when not completely satisfied with the result, immediately for another 24 hours.
Another thought is that a fridge may not function at all, in a cold room. Transfer of heat is totally not the same at all temperatures. Many people have been the same disappointed as you, thinking they can find a cold place for the fridge or freezer. So, when this has happened when the room temperature dropped dramatically, get it out of the cold or shut it down because it performs at its maximum capacity. That is where my bet is at.
The radiator at the back can also not function right when it is close the wall and/or an object is placed right above it. The heat must be dispersed. Best of luck
11/20/2023 5:46:53 AM •
Samsung...
Answered
on Nov 20, 2023
Samsung refrigerator display RD code. How to fix please.
Question edited for a lot more clarity. Please proof read before Posting..
Question moved from Cellphones category. 40,000 to choose from
RD is air damper iced up fault. The damper in the freezer spins around to close/open the air from the freezer to the fridge. It ices up from time to time, or the damper motor, or sensor that reads it's position fails.
Apr 27, 2010
If you can spell it, you can Google it! Lots more in the link. 'make model (what it is)' in all questions please.
https://www.google.com/search?q=Samsung+refrigerator+RD+code
10/22/2023 5:53:54 AM •
Samsung...
Answered
on Oct 22, 2023
I have a Samsung refrigerator/freezer
1Place the appliance thermometer in a glass of water.
2Set the glass of water with the thermometer in the refrigerator on the middle shelf.
3Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
4Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can’t easily see the control dial, check the owner’s manual for a diagram that shows the location
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
5Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
6Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
7Wait at least 24 hours, and then check the refrigerator temperature again.
8Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
90Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
10Repeat the steps as necessary until the temperature is within the safe range.
11Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this helpout...
9/8/2023 10:02:24 AM •
Samsung...
Answered
on Sep 08, 2023
