20 Most Recent Karcher K 2.56 M 1,500 PSI 1.3 GPM Electric Pressure Washer Questions & Answers
How to work a pressure washer?
hook up the water hose before turning electric on have the hose supplying water to it low pressure these units cant take full pressure like over 60psi, thenturn the dial to where you want andconnect power use 3 way adapter prong outdoor style extension with a good outside coded plug receptacle of course
4/4/2016 12:19:06 PM • Karcher K 2.56 M... • Answered on Apr 04, 2016
How can I operate electric washer if mains water unavailable
Run a hose from the inlet (Using appropriate connector) to a tank of water, pond, lake river Etc. You will need a filter box on the submerged end of hose . You can easily make one out of a plastic container with the side cut away and replaced with very fine mesh.
1/5/2016 6:14:02 PM • Karcher K 2.56 M... • Answered on Jan 05, 2016
Karcher K6.85 Pressure Washer. It won't switch on when I turn the switch on. The motor doesn't start?
Question edited for clarity. Use a DVOM to test the switch and the motor. The capacitor may have failed. Does it hum when you turn it on, that is a good indicator of a failed start/run capacitor. https://www.ransomspares.co.uk/parts/brands/karcher/pressure-washer-spares/k6.85m-wb%20gb%20%281.397-502.0%29/ Help and videos https://www.google.com/search?q=karcher+k6.85+doesn%27t+switch+on ..
3/31/2024 5:25:04 PM • Karcher Garden • Answered on Mar 31, 2024
2answers
My karcher K7 seems to keep blowing the fuse in my extension cable..any ideas ??
The following methods, according to Check Appliance, may help you address the problem:
  1. Check that the cable is inserted into the power socket and that the power switch is switched on.
  2. Check to see if connecting into a different power outlet makes a difference.
  3. Check that your extension wire is no longer than 10 meters (30 feet).
  4. Check to see whether the fuse or circuit breaker needs to be reset.
If these methods do not solve the problem, it is conceivable that the pressure switch is malfunctioning, causing the motor to draw too much current and blow the fuse. You should inspect the pressure switch for evidence of damage or dysfunction.
1/14/2024 11:21:43 AM • Karcher Garden • Answered on Jan 14, 2024
Karcher K 4000 G Pressure Washer. Can I buy just the pump for a karcher model 4000g
Question edited for clarity. There are Parts Suppliers in the link E Replacement Parts lists it as obsolete, but there are others that you can check. https://www.google.com/search?q=karcher+model+k+4000+g+pump+replacement ..
1/10/2024 5:48:52 PM • Karcher Garden • Answered on Jan 10, 2024
2answers
Karcher 2000 psi gas 4.0 HP troubleshooting
Have you tried servicing the motor. Fresh air filter, new fuel filter and a fresh spark plug? That will help narrow down what the problem could be.
1/10/2024 1:24:40 PM • Karcher Garden • Answered on Jan 10, 2024
Karcher HDS550c Service Manual please.
It will be like this, HDS Compact Series. Page 27. They are unmistakable, a silver aluminium can with wires coming out of the end. https://karcher-marine.com/wp/wp-content/uploads/Downloads/12722010/Service%20manual-SMA-5290965-002-00.pdf
12/22/2023 12:51:55 AM • Karcher Garden • Answered on Dec 22, 2023
6answers
For my karcher FC5 - the cleaning water doesn't come out ??
I had this problem and partially fixed it accidentally by taking the whole thing to pieces a d re-assembling it and it worked...fir a week. ITS THE GREY BUTTON ...after further failing to release detergent I read about the Grey button being depressed and mine was too ..solid I couldn't get it to pop ip and this is why. Take the bottom cover off to show the detergent tube in its holder...undo the two screws holding the black bracket and gently ease it out...then replace it ..but here's the key.. the bottom of the bracket needs to sit under the grey button ...when I pressed the grey button it on one occasion pushed down lower than the black bracket ( it slipped past the ledge of the black bracket) this prevented the Grey button from coming back up and squeezed the detergent tube closed. So make sure the ledge of the black bracket goes under the bottom of the Grey button.. This took me 5 mi a to fix rather than the 1 hour totally dismantling the whole machine. Remember when pressing the Grey button to clean the cover not tu push down too hard as it will slip below the bracjet ( got to be a design error ) Happy cleaning ???? Andy
12/8/2023 7:22:53 PM • Karcher Garden • Answered on Dec 08, 2023
Karcher K2 Compact - Motor permanently running/no pressure
It sounds like there may be a potential issue with the pressure build-up mechanism in your Karcher K2 compact. The constant motor running without water pressure could indicate a problem with the pump or the pressure switch. I would recommend checking the following:
1. Check the inlet filter: Ensure that the inlet filter is clean and free from any debris or blockages. A clogged filter can restrict water flow and affect pressure.
2. Inspect the nozzle: Make sure the nozzle is not obstructed or damaged. A blocked or damaged nozzle can restrict water flow and affect pressure as well.
3. Check the pressure switch: The pressure switch is responsible for regulating the motor and water flow. It's possible that the switch is faulty or not functioning correctly. Consider contacting Karcher customer support or a professional technician for assistance with checking and possibly replacing the pressure switch.
4. Examine the pump: There might be an issue with the pump itself. It could be worn out, clogged, or experiencing other internal problems. In such cases, it's best to reach out to Karcher customer support or a professional technician for further diagnosis and repair.
Remember to always follow safety precautions and consult the user manual provided by Karcher for specific troubleshooting steps and guidelines.
11/19/2023 12:05:45 PM • Karcher Garden • Answered on Nov 19, 2023
Karcher FC7 cordless low water light comes on when though tank is full
Try descaling it. Limescale film can build up if you leave it filled between uses. Or contact Karcher direct with a request for warranty repair. https://www.google.com/search?q=Karcher+FC7+cordless+low+ater+light+is+on ..
9/20/2023 7:20:40 PM • Karcher Garden • Answered on Sep 20, 2023
2answers
Karcher G2700 pressure washer 196cc Spark plug Gap and size for it please.
their 196 cc 0.028-0.031 in.
4/20/2023 9:10:30 PM • Karcher Garden • Answered on Apr 20, 2023
Karcher HDS 755 detergent not working
Question moved from Laundry Washing Machines to Karcher. Service Manual https://www.manualslib.com/manual/1209347/K-Rcher-Hds-Middle-Series.html?page=20 Owner's Manual in German https://www.libble.de/karcher-hds-755/p/591081/ ..
3/12/2023 8:03:06 PM • Karcher Garden • Answered on Mar 12, 2023
Separate casing on karcher KB9030
There are full strip down videos in this link https://www.google.com/search?q=karcher+KB9030+strip+down ..
3/7/2023 7:03:10 PM • Karcher Garden • Answered on Mar 07, 2023
What spark plug for the k2400hh pressure washer
It should be a Honda GC160 engine.
OEM sparkplug is a NGK BPR6ES @ .030 in. gap
11/19/2022 5:16:44 PM • Karcher Garden • Answered on Nov 19, 2022
Karcher G4-10 Pressure Washer. Who makes the engine please?
Question edited for clarity. It is not mentioned anywhere https://s1.kaercher-media.com/documents/manuals/raw/000/BTA-5173594-000-04.pdf https://www.manualslib.com/manual/1134933/K-Rcher-G-4-10-M.html?page=20 They used to use Honda engines, but my guess is they now use Chinese engines that cost one bowl of rice instead of four. Seems to now be a history of hard starting. https://www.google.com/search?q=Karcher+G4+10%2C+engine+make ..
11/8/2022 9:57:44 PM • Karcher Garden • Answered on Nov 08, 2022
2answers
Karcher window vac screeching when turned on. Why ?
If you can hear the vac squeaking as you run across the window, you've just not applied enough liquid. Just go over the window again with the spray bottle and microfibre cloth and then vacuum the liquid away.
11/1/2022 5:31:22 AM • Karcher Garden • Answered on Nov 01, 2022
Electric Pressure Washer Wont Turn On
I had the same problem. I removed the spray part of the spray gun so I was on soap setting and I had water but when I reconnected the spray wand same thing. * I turned out to be a little bit of grit was in the nozzle. I cleaned out the grit and my spray cleaner worked without a problem.
10/20/2022 6:32:48 AM • Karcher Garden • Answered on Oct 20, 2022
Karcher K 2.56 M 1,500 PSI 1.3 GPM Electric Pressure Washer Logo
5 questions posted
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
View Most Popular
Karcher Garden
  • Karcher Garden
Most Popular Question
operate electric washer mains water
  • Garden
