20 Most Recent HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-316688-002 (316688002) CD-ROM Drive Questions & Answers
Hp zd7000 hinge
If you want a new one Ebay has loads.
5/7/2012 1:40:39 AM • HP Pavilion... • Answered on May 07, 2012
User Guide Manual for zx5000 HP laptop
This is what I could find based on the ZX5000
http://www.hp.com/ctg/Manual/c00212209.pdf
If you need more information go to the link below and select your specific model.
http://www8.hp.com/uk/en/support-drivers.html
7/29/2011 9:13:43 PM • HP Pavilion... • Answered on Jul 29, 2011
How to connect dv camera sony to hp pavilion
install the software that comes with the camcorder and attach it through the cable that comes with the camcorder
9/4/2009 11:52:13 AM • HP Pavilion... • Answered on Sep 04, 2009
Same problemm
If you are having an issue with your back light then 99% of the time it is easier to change the whole screen. Playing around with the back light bulbs could be a real pain and I would suggest looking on eBay or the other usual places you find laptop parts for a screen.
If you are lucky enough that it is the inverter those are much easier to change out. It might be worth looking for one first since they also cost much less than a screen.
8/24/2009 6:39:51 PM • HP Pavilion... • Answered on Aug 24, 2009
My hpzx5078cl laptop will not boot after i had put in a new dc ja
Check the Leds on laptop. Try to turn on the laptop with just the a/c adapter. Disconnect battery,a/c adapter and drain flea power by holding power button for 15 second. Connect /ac adapter and check. Disconnect harddrive and memory from laptop.Reconnect and try to reboot.Possible issue with motherboard.
8/19/2009 5:33:24 PM • HP Pavilion... • Answered on Aug 19, 2009
My hp laptop has a displaced display. Meaning you
A skewed display usually indicates an incorrect driver. Try rolling the driver back or reinstalling it.
However, because you are experiencing the problem at BIOS, its most likely related to the monitor. It could be the inverter or just the screen itself. It might be cause to replace the screen or contact the manufacturer to utilize the warranty, if applicable. Seems like a factory fault.
8/9/2009 1:53:04 AM • HP Pavilion... • Answered on Aug 09, 2009
HP Pavilion notebook's screen is too dark to see!
do u have a external monitor,connect it up and see whether,u r output is any better..
7/26/2009 4:52:46 AM • HP Pavilion... • Answered on Jul 26, 2009
When powered up the screen will not light up at
Take the computer into a DARK room and start it up.
If there now is a faint image on the screen, then the "LCD Inverter" component of the electronics has failed, and needs to be replaced.
It's a $20 part, but you'll have to pay a certified computer technician for 1 hour of labour to replace it.
7/17/2009 2:20:52 PM • HP Pavilion... • Answered on Jul 17, 2009
HP ZV 5000 AC PROBLEM
You either have a bad adapter or a broken power jack in the laptop. To check the adapter use a multimeter set to voltage and connect one lead to the center in and the other to the outside metal contact. You should get a reading from 18 to about 26 volts. If you get no reading then the adapter needs to be replaced. If you get the correct reading then the power jack in the laptop will need to be replaced. If yo are ok with electronics repair you can get the jacks from Ebay.com if not your local computer repair shop should be able to do it for you.
I hope this helps, If so please rate my solution,
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair.
7/8/2009 2:38:20 AM • HP Pavilion... • Answered on Jul 08, 2009
Why won't my computer charge
the battery might be going bad on it, try taking the battery out and running the computer just off of the plug. that series of HP has overheating issues and are prone to randomly shutting down. if you have a bad battery, it can overstress the powersupply trying to charge a bad battery. Also, the solder joints tend to go bad on the motherboard where the power jack is connected to it, so try holding your power wire at a bit of an angle while turning it on and see if that does the trick (the sideways force can temporarily connect those broken joints.. There was also a class action settlement on these computers i believe, so google class action zd7000 and see if you qualify. The power plug jack was part of this, so you might get it fixed free of charge.
7/8/2009 1:06:23 AM • HP Pavilion... • Answered on Jul 08, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered Yesterday
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
Computers & Internet Logo
Popular Tags
11 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
user guide manual zx5000 hp laptop
  • Computers & Internet
