20 Most Recent HP Pavilion ZV5000 ZX5000 Compaq R3000t R3200 series 15.4-inch TFT WXGA LCD Display-350217-001 (350217001) CD-ROM Drive Questions & Answers
Media test failure Check Cable or error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
HP Pavilion... • Answered on Mar 30, 2011
could be a heat problem. remove the back cover and check to insure the prcessor id getting proper ventilation. the heat sink may be covered with dust.
HP Pavilion... • Answered on Nov 29, 2010
did you change the little inverter board? check your brightness by pushing Fn key and left, or right arrow buttons.
HP Pavilion... • Answered on Aug 12, 2010
hey buddy....
if u wanna step by guide for u ODD hardware assembly.....
check out the following link.... kindly scroll down a little.... u ll see something called as hardware guide..... kindly download that manual.....
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=321957&prodSeriesId=369807
its a legitimate hp link for u zx5000.... so u dont have to worry or doubt about the procedures....
i would also recommend u to download all the other manuals pertaining to ur zx5000 from there ..just incase...
it wud be mighty helpful for ya...
hope i was help
thank you
have a nice day
HP Pavilion... • Answered on Apr 10, 2009
you need to remove and install the battery. Some times this works first try others may take a few trys. Mine does the same thing. Good luck
HP Pavilion... • Answered on Jan 13, 2009
Download or get a memory test utility that boots from some device (a floppy, flash drive or CD-ROM) that your PC can read. Run that test to confirm the installed memory is good/compatible. Loose memory modules and PC boards can be zapped just by touching the connector pins while you handle them. During removal or installation you have to frequently touch the machine's frame or wear an ESD strap before handling the module, to prevent this.
HP Pavilion... • Answered on Oct 22, 2008
Found my solution. Was under keyboard. Required opening laptop as far as possible, removing 3 screws from the back that hold the piece of plastic just above the keyboard. With flathead screwdriver lift the right corner of the plastic piece then, with the same screwdriver lift the top center of the plastic piece to remove the piece entirely. Unscrew the 4 screws that hold the keyboard (across the top) and lay they keyboard forward (toward you). THERE is the Ram.
HP Pavilion... • Answered on May 23, 2008
does rebooting fix the issue? if so it could be a driver issue.
However I believe its probably a loose ribbon cable. It happens from time to time, the cable eventually loosens up. If your mechanically inclined you can open up the laptop and secure the cable. However if you have never opened up a laptop, theres a good chance you will break a piece of plastic as they are fragile and force must be used in the correct places.
HP Pavilion... • Answered on Mar 16, 2008
The keys on your laptop computer needs to be replaced and have a person that repairs and fixes computers to have a look at your laptop and see if the keys can be repaired or not for your laptop.
HP Computers &... • Answered Yesterday
windows 7??????????????????????i went to hp.com and there is only XP and W7 support on this 12 year old pC, this is A FACT.what OS is there.?in the run box, type start run, type, WINVER,(ENTER)BINGO OS , TOLD NOW, if windows. of Linux say LINUX.!"I Installed .synaptics drivers " you said.from where? HP.com w7 or XPor from the 1million infected driver websites from H3LLor from maker synaptics.com or?where ?now my longer answer for only w7 ok.1: be internet connected first are you, on bad PC. MUST BE.2: in device manager go to mouse and pointing devices. (conrol panel (CP) click Device manager)see Synaptics there , and right click it and and choose uninstalll device.3: now reboot PC, by start + shut down.4 off it is.5: push power button 10 seconds and release (resets PC)6: go to step2 above make sure synaptics looks happy there. does it, no errors?7: now go to CP + mouse and check all settings here.on HP they are not simple, some have 2 drivers working there for synaptics pad, one for the pad and one for buttons.only HP.com drivers work, for sure true on all my Eitebooks here.use only HP.com drivers. no others. or it will failand the driver needs to match YOUR UNSTATED OS.I sure hope you did not get w10 here. it does not belong here.NO OS TOLD why in the world post lacking such a very very key fact, why>??after all Drivers match OS.
HP Computers &... • Answered 2 days ago
sadly the only place i can suggest is a computer repair shop
HP Computers &... • Answered on Apr 27, 2021
If you are lucky the drive may just need plugging back in, but I suspect the board may be damaged if the BIOS cannot 'see' it.
HP Computers &... • Answered on Apr 26, 2021
music download software http://100-downloads.com/download.php?p=682 spotify Instant and legal access to over 10 million music tracks http://www.artistdirect.com/music http://mobile.afreecodec.com/free-songs-download-87079.html once the music starts to download a browse option will open where you will need to select if you want to run or safe
you should always keep your antivirus up to date when using any file sharing programs on the internet
hope this helps
HP Computers &... • Answered on Apr 15, 2021
Computers & Internet Logo
11 questions posted
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
display working but no brightness
  • Computers & Internet
