20 Most Recent Waring Pro WO50 Cordless Wine Opener Questions & Answers
Replacing requires some soldering skills.
1. Remove two screws in bottom end and pull off the bottom sheath.
2. Remove six rubber plugs that camouflage six screws.
3. Remove the six screws. The opener will come apart in halves and the motor assembly may drop free but will still be connected so be a little careful. Take note of the orientation of the larger spring near the bottom and the positions of fittings that mate with the shell.
4. Unsolder two leads connected to the old battery pack and remove it.
5. Now you have options for replacing the battery pack. The pack consists of four Nickel Metal Hydride batteries connected in series.
a. Buy replacements (I didn't do this so I don't know if a pack is available that is already assembled). You might have to buy four same-size batteries and assemble the pack yourself. You can determine size by cutting the shrink wrap away from the battery pack to expose the actual batteries.
b. Buy standard AA (or AAA) cells, rechargeable (Nickel Metal Hydride) cells that are readily available everywhere.
6. (Unnecessary if you found a pre-assembled pack). Assemble a battery pack by soldering battery terminal to battery terminal such that all four batteries are in series. You can arrange adjacent batteries with a plus terminal and a minus terminal next to each other. You can make the four batteries into a pack by winding them with electrical tape.
7. (Unnecessary if you chose step 5A). Using a sharp knife or a Dremel tool, whittle away most of three ribs that are formed into the plastic shell. There are two ribs to do in one of the shell halves and one(+) rib in the other shell half. The (+) rib is near the connector block mounted under the operating switch and you can decide how much of it to whittle away also. The objective is to get the new battery pack to fit in the shell halves when they are re-assembled.
8. Solder the plus(red) wire and the minus(black) wire to the new battery pack -- those are the two wires removed in step 4.
9. Add padding if you desire to keep the battery pack from rattling around inside the shells.
10. Reassemble the shells and the bottom sheath.
11. Enjoy your wine.
Waring Pro WO50... | Answered on Apr 17, 2020
A broken cork was stuck up inside my Waring Pro Wine Opener. Model WO50B. No amount of maneuvering could get it out. I removed the two small screws holding the silver part of the opener on. After that was off I could see two more screws and I removed those. The unit still would not come apart. I noticed that there were four oval shaped rubber plugs up on the black part of the unit. I pried the ovals out with a wooden skewer. That exposed the other four screws holding the long part of the unit together. Once I got those out, I gently pulled the two sides apart about an inch. I could have pulled it completely apart at that point (I think) but from there I was able to free the broken cork from the big internal cork screw. Everything screwed back together fine and the unit works again.
Waring Pro WO50... | Answered on Jan 10, 2018
amazing that noone has answered this question including the people at Waring - I have no idea how to do this
Waring Pro WO50... | Answered on Sep 06, 2016
It is not available. Someone bought one on ebay and soldered it in. I am going to try it myself.
Waring Pro WO50... | Answered on Feb 22, 2015
Battery may be soft. N/G
If it goes in with No Problem and will not pull out
Waring Pro WO50... | Answered on May 21, 2014
This is from Jen8926 in another forum and it worked for me (push up the inner sleeve an inch or more inside the main tube): Use a screwdriver (or whatever) to push the inner ring at the opening as far inside the appliance as you can. It is a black piece with a spring action that has plastic molded ridges inside. The ridges on the inner edge of this will grasp the cork. Then, while you are holding the inner section in place as far inside as possible, push the button to operate the opener and the cork should come out as it normally should. I had half a cork stuck up there, and this just worked perfectly.
Waring Pro WO50... | Answered on Jun 14, 2013
Waring Pro WO50 Cordless Wine Opener Logo
Popular Tags
28 questions posted
Top Waring Home Experts
john h
Tom Chichester
Are you a Waring Home Expert? Answer questions, earn points and help others
View Most Popular
Waring Home
  • Waring Home
Most Popular Question
replace battery in waring pro wine
  • Home
