20 Most Recent
Sears 25 cc Gas Blower Questions & Answers
Have Sears 358.794741 Gas Blower that quit and
ARE u certain fuel is reaching piston? do a 1/2 sirenge-force' fuel thru carb into the cylinder and try to start if nothing' check compression using a any conventional engine comp gage if compression is 95 or lower entire unit is toast!! most 2-strokes including huska ,echo and stihl will egg-shape cylinder-walls due to wrong mix!!! and happens over two to three hrs use with wrong mix..2 stroke ANTHING MUST be perfect in fresh-fuel with fresh proper oil mis usually 40-1 unlike trimmers most are 32-1 as is chain saws..compression test is always done 1st before i look for da obvious no-spart/fuel da cheapest fix.. for weak or little comp the unit MUST be used for parts and buy an identical unit and use it right!
