20 Most Recent Miele 20 in. KM405 Gas Cooktop Questions & Answers
Burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
7/18/2022 12:58:19 PM • Miele 20 in.... • Answered on Jul 18, 2022
The oven on my gas cooker will light but wont stay lit
Thermo coupling needs changing, unless you are Gas Safe, let someone else repair for you, its a common problem, shouldn't cost much, good luck , the Yeti
5/20/2009 6:49:39 PM • Miele 20 in.... • Answered on May 20, 2009
Miele induction stovetop error FE31? It caused my fuse to blow but now can't get it to work. Any ideas?
Finally I found the meaning of FE 31. FE31 means "control panel is dirty" or "some object is on the control panel" When error code FE31 appear on the control panel, clean the control panel area with clean wet paper towel or remove any object on the control panel. If you do not trust me, turn on the cooktop and put small piece of paper towel on control panel. You cannot see FE31 error code soon. Turn off the cooktop and remove the piece of paper towel, the error code EF31 will disappear.
12/27/2022 2:58:04 PM • Miele Cooktops • Answered on Dec 27, 2022
Hi I have a Miele KM5676 cooktop. I'm getting a FE error.
It is a generic hardware error and should contain a number which pinpoints the fault. You will likely need a service call. https://www.google.com/search?q=Miele+KM5676+cooktop.+FE+error ..
10/19/2022 10:48:19 PM • Miele Cooktops • Answered on Oct 19, 2022
Miele HR1124 cooktop - turning one burner on keeps igniter clicking for all 4 burners.
It is a gas appliance and it is a Miele, so you need a registered gas technician to service it. In my experience, the spark igniters work on all burners. To clean the burners, remove them all and put them in a large saucepan. Add cold water and dish liquid, bring slowly to a simmer and turn off. When cold, rinse and scrub with a plastic pot brush, paying particular attention to holes and slots. This was a job we did in the restaurant every week. It is a good plan to do before you go to bed for the least disruption. The product specs says; Automatic re-ignitionSealed burners • M Pro Dual Stacked Burner System So perhaps my hack won't work if they aren't removable. I found this video :>) https://blog.yaleappliance.com/new-miele-hr1124-30-inch-professional-gas-range ..
2/19/2022 5:43:34 PM • Miele Cooktops • Answered on Feb 19, 2022
2answers
We can not turn on stays locked ;we have an Miele induction cook top
https://www.coolblue.nl/en/advice/errors-miele-induction-cooktops.html How do I unlock my Miele cooktop? Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time. Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time. If this doesn't unlock when you do this then you have a problem with the control board.
11/17/2021 11:18:00 AM • Miele Cooktops • Answered on Nov 17, 2021
Miele KM-493 induction stove. What does error E13 indicate?
  • Error code E13 error showing on display
  • What causes an E13, E 13 error code on the Induction Cooktop control panel?
  • Error code 13 on Induction Cooktop control panel
Cause:
  • Universal OFF key failure
Troubleshooting:
  1. If the controls are wet or water made contact with them, dry off the controls.
  2. Turn off then back on to reset.
  3. If the error persists, reset the unit at the circuit breaker.
  4. Turn the unit back on to see if the error code cleared.
6/26/2021 2:41:16 PM • Miele Cooktops • Answered on Jun 26, 2021
I have a Miele induction cook top flashing E80
That will not matter
1/5/2020 7:15:33 AM • Miele Cooktops • Answered on Jan 05, 2020
2answers
Miele induction stovetop dE error?
Miele cooktop induction KM 6350, 6380, 6382, 6383 dE mode
How to switch off demonstration mode
Press ‘power’ button on front and ‘lock’ bottom at same time until you get p5 mode displaying ( it is in programming) mode.
Then press top left to ‘0’, bottom left panel to ‘0’, then press right bottom panel to 9, then press on ‘power’ button to save. This should take it off demonstration mode.
6/7/2019 4:59:14 AM • Miele Cooktops • Answered on Jun 07, 2019
2answers
2answers
What does dE mean on miele induction cooktop?
Most likely Door error
11/20/2018 6:25:57 PM • Miele Cooktops • Answered on Nov 20, 2018
Need repair of vent/fan on Miele gas cooktop. Zip is 04107
fixya doesnt send service personal notify a service repair company in your area
11/4/2018 3:26:28 PM • Miele Cooktops • Answered on Nov 04, 2018
Miele induction stovetop dE error? the stove will not heat up
Wrong pan
5/16/2018 12:32:28 AM • Miele Cooktops • Answered on May 16, 2018
I have a Miele electric cooktop KM5840 and one burner does not work. It will not come on at all.
Unless you have electrical skills I suggest have a qualified electrician check it. If you do have skills, obtain a volt/ohm meter and test the element for continuity and the socket for power. My guess you need a new element.
12/2/2017 7:13:09 PM • Miele Cooktops • Answered on Dec 02, 2017
We have modern Miele induction hob not sure of model it has three single hot plate, one large double extra speed hot plate one double hot plate its in demonstration mod how can l cancel?
I am assuming the timer display is showing "dE" . If you have the manual page 50 (programming) shows how to cancel demo mode. It is program P 0, currently it is set to "0" (demo mode), you need to change it to "1" (demo mode off).
11/30/2017 5:20:27 PM • Miele Cooktops • Answered on Nov 30, 2017
My miele electric cooktop will not stay on after I trip the circuit.
Without more info this is difficult to answer. I will say that all cooktop's have thermal overload switches built into them. They open the circuit until it all cools down and they then close the circuit and reset. You begin using it again and bang it opens again and no power. This means you have a short circuit or a bad overload switch. If you are tripping the circuit breaker, you likely have a short circuit, which is why it is tripping the breaker. I would not keep resetting it, if this is the case. The more you blow or open the breaker the weaker it becomes. They open to prevent an electrical fire, which you do not want.
11/3/2017 7:11:59 PM • Miele Cooktops • Answered on Nov 03, 2017
I have a Miele KM405 and 406 miele gas hobs what size lpg gas conversion jets should i buy
You should get the conversion supplied by the manufacture. That is the only way you should do it
10/2/2017 12:30:45 PM • Miele Cooktops • Answered on Oct 02, 2017
Miele 20 in. KM405 Gas Cooktop Logo
Popular Tags
7 questions posted
Top Miele Cooktops Experts
Paul Carew
john h
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Miele Cooktops
  • Miele Cooktops
Most Popular Question
oven gas cooker will light but wont stay
  • Cooktops
