20 Most Recent Kenmore Refridgerator Air Flow Diffuser Part W10151374 Questions & Answers
I usually use very hot water alil at a time onto the hole drain spout, and I have a soft long flexable tube that I insert into the whole ( the condensator) to clean out the blockage and debris. can use coat hanger but be very careful as can damage the tube drain line. unplug the drain line from bottom of drip pan and place towel under it, u can also try to blow into the flexable tubing down towards the drip pan if its not solid
Kenmore... | Answered on Feb 20, 2015
Unless the fan works there will not be any flow to the fridge section as the cooling comes from the freezer coils. check the fan and replace after checking the power to the fan.
Kenmore... | Answered on Jan 31, 2013
call a local repair service you might need a new air damper motor
Kenmore... | Answered on Mar 24, 2020
if I could see it perhaps I could tell however have never seen one
Kenmore... | Answered on Mar 23, 2020
Check to see if the unit it level, sounds like it is not. The unit may be like a Samsung model that has this issue. The tray that catches the ice is supposed to be slanted towards the back of the unit.
Kenmore... | Answered on Mar 21, 2020
go find the manual at sears website and check it out
Kenmore... | Answered on Mar 15, 2020
Evaporator fan may be variable speed depending on need. Spray the motor bearing with dry silicone spray.
www.jigaloo.ca
Jig-A-Loo, an invisible silicone-based lubricant and water-repellent that doesn't stain or stink. It stops squeaks, lubricates, loosens and prevents rust and dust. ‎JIG-A-LOO lubricant · ‎Retailers · ‎Garage Door Lubricant · ‎Uses
Kenmore... | Answered on Mar 10, 2020
Pull it out and clean the back. When you re position it, put it in a slightly different spot. If it has a kick strip and filter at the bottom, clean that too. The humming is caused by harmonics and just needs a small change to get rid of it.
Kenmore... | Answered on Mar 09, 2020
This can be a complex problem. Test whether the defrost heater circuit is getting 120 v from the main control board. If it is getting the voltage, the main control board is okay. You could have a broken heating element or a blown fuse in the defrost control assembly. Here's a video for a different error code that shows how to access the freezer evaporator in that type of refrigerator: youtube.com/watch?v=a4MdwuoN3jc Unplug the refrigerator and use the procedure in that video to remove the evaporator cover in the freezer. Check the resistance through the defrost heater and replace it if it's electrical open (measures infinite resistance). If the defrost heater is okay, you may need to replace the defrost control assembly which contains the defrost thermistor and fuse. You might want to call a service person on this.
Kenmore... | Answered on Feb 19, 2020
u more than likely have to remove the bottom plate first and the screws along the back wall are most likely covered with a plastic covering
Kenmore... | Answered on Jan 14, 2020
Kenmore Refridgerator Air Flow Diffuser Part W10151374 Logo
7 questions posted
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
small hole back fridge keeps icing over
  • Refrigerators
