20 Most Recent
Miele 36 in. KM342 Gas Cooktop Questions & Answers
Electric ignitors clicking
I'm sorry that I don't have a solution for you, but my Miele gas stove does the same thing. I had a repairman come out while it was under warrantee and they fixed it, but it was only temporary. It's doing it again, but, of course, it's no longer under warantee and will be very expensive to have Miele come out again. I've found that it's the right front burner that causes the clicking, so I've just stopped using it.
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
I have a Miele cooktop
I have the Miele km342g cooktop. The ignition would continue firing intermittently after the burner was lit - click, click, click. Drove us crazy for years and we cursed the unit every time we used it. We assumed it was sensing unburned fumes and so we bought a small fan to "whisk" the gas fumes away. etc. etc. I finally figured out what a simple little thing it was. To start the burner, you turn the knob counter-clockwise. Therefore, once the burner is lit it's intuitive to turn the burner down by turning it clockwise. But in order to turn the burner down, you have to continue turning it counter-clockwise - or, "counter-intuitive". Once we figured that out, we haven't had a problem since.
All the knobs have cracked
My knobs did the same _ if you want to avoid expensive replacements (mine were going to be $125) get some small good quality zap straps and tighten 2-3 around the stem. For added strength you could add some apoxy but i found it was not necessary. Good Luck!
My Miele KM342 cooktop has
Have you tried to just move the knob away from the 'Start" position. this sounds like the ignitor is still engaged. Aside from that, I'm not sure of a solution.
Hi I have a Miele
Hi jennifer20,
I believe those ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
