20 Most Recent HP Compaq ProLiant DL360 G3 Server Questions & Answers
Check and Clean Processor FAN and all cooling Fans inside the server.
Check the cable connectivity of the CPU Fan on the M/B.
Update server with Latest BIOS firmware.
HP Compaq... | Answered on Nov 28, 2011
Update BIOS and COLD BOOT the Server Once.
This is a long shot, but:
  • Get into BIOS settings
  • System Options, Diskette Boot Control, Disabled
  • Save on Exit
Machines from 2006 were really not very good at booting from USB.
HP Compaq... | Answered on Feb 28, 2011
From my experience, this is an indication that your fans need replacing. If your system manager is working properly, at night if your system is not use much, the manager will put the system in a low state of operation, almost like hybernation. When a request come in to 'wake-up' the system, the fans do not spin fast enough to cool your system properly thus the errors.
Replace the fans, recheck your settings in system manager making sure the manager software is monitoring the cooling and not the os. This should solve your issue.
Good Luck
C2Solutions
HP Compaq... | Answered on Jan 18, 2011
You firstly have to make your usb key bootable just google instructions on how to do that.
Set the boot order in the bios to boot from it and then transfer the image to the usb key and install from it.
HP Compaq... | Answered on Nov 18, 2010
Remove all 6 fans, and then remove the fan rack itself. Then tighten the 2 pcb thumb-screws underneath. I believe this is sometimes the reason for false 'failed fan' reports.
HP Compaq... | Answered on Sep 11, 2010
Si el sistema operativo no reconoce tus disco, y ya has creado un arreglo nivel 1 o 5 y en la bios si puedes ver los dicos, el problema es posiblemente que necesites cargar los drivers de la controladora. Si puedes ver el modelo de la controladora (visible en el post) dirigete a la pagina de hp.com/support escoje el pais USA para que tengas acceso a todos los drivers, descargate el ultimo driver de tu controladora y cuando este instalando windows presiona f6 para cargar los drivers
HP Compaq... | Answered on Aug 30, 2010
Hi there Jim,
You will require the HP ProLiant Integrated Lights-Out Management Interface Driver for Windows Server 2003.
You can acquire this here. Let me know of any problems.
Please do not rate this reply unless I have solved your problem or your reply will not be returned to me.
Regards
nLinked
HP Compaq... | Answered on Aug 06, 2009
Seems like either your display is gone or *********** board or FRU has some serious problem.
Please contact HP support/services.
Regards,
HP Compaq... | Answered on Jul 10, 2009
Have you connected a CD drive to the machine via one of the SATA ports?
HP ProLiant... | Answered on Sep 15, 2015
When you turn it on, does the fan come on? How about the hard drive? There is a serries of tests called POST. I amc4rying to find out what starts up and see where the problem is.
HP ProLiant... | Answered on Jul 08, 2015
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways.
BE SPECIFIC.
HP ProLiant... | Answered on Jun 13, 2015
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
HP ProLiant... | Answered on Jun 12, 2014
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
HP ProLiant... | Answered on Dec 10, 2013
HP Compaq ProLiant DL360 G3 Server Logo
Popular Tags
15 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProLiant HP
  • ProLiant HP
Most Popular Question
am trying boot hp dl360 g3 from flash
  • Computers & Internet
