20 Most Recent HP Compaq Proliant DL350 (345101-001) Server Questions & Answers
Big noise? Power Supply?
Even t log wouldn't always pick up a hardware failure that kills the machine. Goto HP Download diagnostic spoftware and see if that gives an answer.
Either that or when it does it, pull the lid off, listen to see where the noise is coming from (I.E. Power Supply, drives.. etc) and replace as neccesary.
HP Compaq... | Answered on Sep 09, 2010
The solution depends on exactly where it stalls. IF it stalls while booting the OS, either the OS files are corrupted so better try the recovery console or using the recovery CD.
Verify in the boot bios screen whether all the hardware are detected properly
HP Compaq... | Answered on Mar 20, 2010
You need a database program - Microsoft SQL, MySql, Access, etc... Setting up RAID will help your speed.
HP Compaq... | Answered on Apr 23, 2009
As standard it has 1x Xeon single core 3.2GHz with a 2nd free CPU Socket
HP Compaq... | Answered on Jan 20, 2009
Have you connected a CD drive to the machine via one of the SATA ports?
HP ProLiant... | Answered on Sep 15, 2015
When you turn it on, does the fan come on? How about the hard drive? There is a serries of tests called POST. I amc4rying to find out what starts up and see where the problem is.
HP ProLiant... | Answered on Jul 08, 2015
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways.
BE SPECIFIC.
HP ProLiant... | Answered on Jun 13, 2015
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
HP ProLiant... | Answered on Jun 12, 2014
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
HP ProLiant... | Answered on Dec 10, 2013
What happens when you try to attach them
HP ProLiant... | Answered on Nov 10, 2013
If you lost everything then you've obviously reloaded all your software for the server, now you need to load your daily backup tapes onto the server so you can have mail again. you will also need to know all of your DNS's and you MX records if you're running exchange and if you don't know how to do any of it, then my suggestion is to hire a network administrator and it'll cost between $1k - $1.5k by time he's done bringing your system back online.
HP ProLiant... | Answered on Oct 29, 2013
Order from HP - Front bezel key 459183-001
HP ProLiant... | Answered on Dec 12, 2012
Test the UPS. The server will stay up as long as there is power and has not overheated, should it be a cool room.
HP ProLiant... | Answered on Aug 28, 2012
How big is your UPS backup. Small home / office only last a few hours before the battery drains. Their role is to allow time to save work and shut properly. Large enterprise UPS's last longer, but are dependent on battery bank size and configuration.
Clear NVRAM by switching ON Maintainance Switch 6.
HP ProLiant... | Answered on Apr 17, 2012
awwww maaaaaaan never use that thing! It is nothing but trouble. If you need to reset your G4 get a repair/reinstall disk or flashdrive off eBay. Sets it up brand new for less then $15 if you look hard enough. Many uses too.
(The Whoo)
HP Computers &... | Answered on Oct 20, 2020
HP Compaq Proliant DL350 (345101-001) Server Logo
4 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProLiant HP
  • ProLiant HP
Most Popular Question
using hp dl360
  • Computers & Internet
