20 Most Recent Miele CatAndDog700 Bagged Canister Vacuum Questions & Answers
try going to the shop where you bought it and see how to attach the bag properly
Miele... | Answered on Dec 23, 2017
Hello, this is Ava with Think Crucial.
You may find your User's Manual for your Miele model using the link provided below.
https://preview.u-manual.com/preview-manual-for-free-131796/vacuum-cleaner-miele-s310i/page-1.html
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Miele... | Answered on May 07, 2017
set big Cat to stay on porch. (Smile)
Miele... | Answered on Mar 27, 2016
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Miele... | Answered on Jul 29, 2013
typically if your vacuum is loosing performance it is time to replace the bag depends on how fine of dust some really fine dust will clog the pores at a 1/4 full
Miele... | Answered on Apr 15, 2013
I have seen generic filters do this. Be sure to use original Miele filters. The generics are a few dollars cheaper to buy but you end up with an inferior quality filter that could cause other problems by continued use. same is true with bags.
A clogged filter may also do this. Miele vacuums are very tightly sealed, the exhaust air has to come out. If the filter is clogged, the pressure could pop the filter out, HEPA filters are suggested to change out about every 50 hours, for most people this is between 1 - 1.5 years.
We had a Miele come in for service the other day with the same complaint, installed filter was a generic, customer said it was a new filter just installed. We replaced with an original filter and problem ceased.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Miele... | Answered on Mar 22, 2013
ereplacementparts.com
Miele... | Answered on Feb 20, 2013
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Miele... | Answered on Dec 26, 2012
you will need to take the unit apart find the screws that hold the unit together 2 under the the bin cover at the hinges 1 holding the black control cover when you have removed the screw then just lift the cover it will be stiff just pull it up under this find all the screws and remove them remove the motor and you will see the pcb on the side of the motor it will have a dry joint on the solder this back up and that should do it make sure you unplug the unit b4 you work on it
Miele... | Answered on Oct 16, 2010
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Miele... | Answered on Dec 02, 2008
Yes they can be used together, and they would fit in the same slot if there is room.
Miele... | Answered on Mar 11, 2008
opposite of how you took it apart I would assume
Miele Vacuums | Answered 2 days ago
Bearings need some grease or replacement
Miele Vacuums | Answered on Mar 22, 2020
Miele CatAndDog700 Bagged Canister Vacuum Logo
28 questions posted
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
john h
Mike
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Miele Vacuums
  • Miele Vacuums
Most Popular Question
miele solarus canister vacuum stopped
  • Vacuums
