20 Most Recent
HP DesignJet 488ca InkJet Printer Questions & Answers
"media" error light after load
check the media lever ..it must be lowered if you inserted media /in our case the media button have to be pushed to indicate roll media..The media led flashes also when the media is not aligned proper..In this case you have to take it out ..by lowering the media lever ..and raising the metal guard.. take it out and insert it again ...
here is manual for it ..and on the chapter * and ( you have about media and media troubleshooting ..
http://h20000.www2.hp.com/bc/docs/support/SupportManual/bpp02529/bpp02529.pdf
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead.
My advice is not to stock up on cartridges because of this problem.
If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
