20 Most Recent
HP DeskJet 820cxi InkJet Printer Questions & Answers
Connection
You may need to use usb to parallel cable.For drivers,please see link belowhttp://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=58154&lang=en
I need to get downloads
Hello, fortunately HP have got a fantastic website. All you have to do is type in www.hp.com
When the page opens, click on the 'Support & Drivers' link near the top of the page, and then follow the links to what you need to download, (be it drivers or manuals)
Regards,
nicam49
Looking for drivers for hp DeskJet820Cxi os
this particular printer never have driver for win2k, i would suggest downloading winnt4 driver or alternatively win95/98/me driver and bit fiddle with installation,
particulary winnt4 driver should work without much hitch on win2k.
your link on hp site is going nowhere as there never was a driver for this printer beyond winnt4...
HP Deskjet 1000C
put some sewing machine oil on the silver slide bar.dont get any oil on other parts
Software required NOT DRIVER: HP Deskjet 820Cxi
LOL! Click on this link and look at all the drivers for all the operating systems. There is a reason that you have no software. This printer was designed for Win 95/98/ME. It's that old. Any future systems use the Windows driver for basic printing and there is no Control Center panel for W2000 and greater software.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=58154&lc=en&cc=us&dlc=en&lang=en&cc=us
IIRC, this printer is nothing special, and you can actually get a better printer for less than $60 and the local ChinaMart that has better interfacing and capabilities. In fact, you can get a printer/scanner/copier and upgrade your system.
Carl who just tossed his 930.
HP Deskjet 820cxi printer - Paper got stuck and
Try cleaning the encoder strip. It is the clear strip that runs from left to right . It is above the steel rod. Be very carefull to not pull it off of the hooks on each end. It is very hard to get it back on. If that does not help, try holding down one or both of the buttons on the panel while plugging it in.
Changing ink carthrige
hi try to clean the contact point of ink and ink carrier.if it's not work 2 thing you need to consider....
1.maybe your ink is not compatible or not detected..
2.maybe your ink carrier is most likely defective.
hope this would help you...
COLOR DOES NOT PRINT, NEW CARTRIGE INSTALLED
Solution #6
posted on Oct 12, 2008
mohammed387
Rank: Wiz
Rating: 79%, 100 votes
contact service center..if u have warranty.. THIS LAST WARING MOHAMMED DONT ANSER ?S U DONT KNOW WHAT U ARE DOING IN THIS IS YOUR LAST WARING THX FIX-YA
10/13/2008 12:26:26 AM •
HP DeskJet...
Answered
on Oct 13, 2008
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
My printer cutting text from the right side when printing .HP deskjet 2050 J510
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
