20 Most Recent HP DeskJet 970cse InkJet Printer Questions & Answers
HP 970 cse printer Orange light flashing, but no papter jam. Green power light is lit. cannot print ? :(
There may be a small piece of torn paper in the path obstructing a sensor. Have a good look to see if you can find it.
8/12/2016 8:09:04 PM • HP DeskJet... • Answered on Aug 12, 2016
Feed paper light stays on, and paper doesn't feed through
hi im josh in cebu phils. friend if it stays lighted on and cartrdge move side to side. ther problem is in your paper feeder it wont detec the paper because maybe it is already covered with dirt and dust. try to clean it. good lcuk
11/13/2013 9:56:58 AM • HP DeskJet... • Answered on Nov 13, 2013
2answers
Yellow ink doesn't print from
Try to change ink jet cartridge with a new one from hp and then blow off the contacts with compressed air. Make sure the tape is removed from the nozzles of the ink jet cartridge before installation.
Good luck on this repair.
5/22/2013 5:38:37 PM • HP DeskJet... • Answered on May 22, 2013
Printer is printing symbols and other characters
symbols and other characters like &^%$$#@!@#$%^&*())_+ ...etc ?its just a bad connection to PC OR reinstall the software.i hope its helpful.
12/2/2012 9:42:30 AM • HP DeskJet... • Answered on Dec 02, 2012
HP DeskJet 970Cse cartridges won't move
okay be gentle, but try to move the cartridge box manually from side to side. it's possible that the gears have gotten stripped which is why they won't move even though they are trying to. so i'd try and move them from side to side and see if you can physically move it yourself. like i said be gentle in the chance the gear isn't stripped. good luck! If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
2/10/2012 5:59:00 AM • HP DeskJet... • Answered on Feb 10, 2012
My printer won't shut off or print, lights
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels. Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
11/10/2011 11:28:45 AM • HP DeskJet... • Answered on Nov 10, 2011
Check ink levels
Hi,To check the ink level go to the printer properties in control panel. When you give any print job the the task bar icon of printer shows the ink levels.
10/20/2011 8:57:23 PM • HP DeskJet... • Answered on Oct 20, 2011
4answers
Printer tries three times to
Welcome to FixYa.
Have you tried to do a hard reset first? Here's how.
  • While the computer and printer is ON, unplug the power cord from the power outlet.
  • Unplug the USB cable of the printer.
  • Restart your computer.
  • Plug back the USB cable and the Power cord.
  • Turn ON the printer is it is OFF.
If this does not resolve the issue then there might be something blocking the cartridge pathway or the "belt" needs to be replaced (This is common to deskjets).
  • To open the printer, remove the screws underneath the printer. There are about 4 to 6 star crews)
  • The top cover can now be removed.
  • Check for any objects or torn paper that is blocking the pathway.
  • Put some grease on the rod where the cartridge glides/sits.
If this does not resolve the issue. Replace the "Belt". Part number C6426-40115. Refer to the picture below #4.
If it still does not resolve the issue, the transparent guide (#3 in the picture) is damaged.
The transparent guide which has a mechanism embedded in it has no replacement. This is a common issue for deskjets. You might consider a repair from the manufacturer if it is still in warranty or buying a new printer.
I hope I have provided you with useful information that will save you time and money in searching for a fix.
Keep me posted.
Jas247
8/21/2011 1:44:23 PM • HP DeskJet... • Answered on Aug 21, 2011
HP 970Cse. The printer
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having.http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09315&cc=us&dlc=en&lc=en&product=60097&tmp_track_link=ot_search
8/18/2011 3:05:56 AM • HP DeskJet... • Answered on Aug 18, 2011
Sudden problem with formerly flawless
What operating system do you have on the computer to which you are connecting the printer to?
8/6/2011 4:30:41 PM • HP DeskJet... • Answered on Aug 06, 2011
0answers
2answers
970 Cse cartridges bang over to the left and then nothing
I had the same problem with my HP Deskjet 970Cse which was quickly resolved by going to the below HP site and looking under the Issue: The carriage is stuck or makes a grinding noise. Note that the blinking lights displayed as: Resume Light Blinking Simultaneously AND Power Light Blinking Simultaneously.
The Solution:
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cable from the back of the printer when the grinding noise starts.
4. Move the carriage towards the middle of the printer.
5. Take out the cartridges and close the top cover.
6. Plug the power cord to the back of the printer. Turn the printer on.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Hope this helps as it worked for me.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&lc=en&cc=us&lang=en&product=60097&dlc=en
4/4/2011 4:07:29 AM • HP DeskJet... • Answered on Apr 04, 2011
Printer keeps printing same file
My friend, the computer and printer do what you tell them to.
Jobs are sent from the computer to the print Que and are printed according to the instructions you have provided. This is a very long shot. I suggest you open the print Que and see if there are any jobs pending. Sometimes jobs get stuck and are waiting for manual instruction from you. If jobs are stuck there - cancel or delete them. In a few very unusual cases, they will not cancel nor delete. What I do in this case is I remove the printer from the system, reboot my computer and reinstall the printer. I don't think this is necessary in your case, however.
Find the printer icon on the bar at the bottom of your window ... to the right side. Click on it and the que will open up. If it is not there, there are no jobs pending - so - send a job to the printer which will cause the icon to appear.
I think your trouble is you are not sending the job that you think you are. Assure the file you want is open then print it from within that application for best results.
Thanks for your question at FixYa.com
1/28/2011 2:50:39 PM • HP DeskJet... • Answered on Jan 28, 2011
2answers
Pages do not kick out after printing on my HP DeskJet 970
It looks like a driver or software problem. I would check whether there is a newer driver (last time I looked the newest was 2002!!!) and whether a new installation helps (watch out sometime one must install before the printer is hooked to the PC and sometimes it is the reverse check the manual).
I would also check whether it occurs with all software...
A couple of info would be helpful: which OS are you using? is the printer running over USB or parallel. Is the printer attached to a printer server?
9/12/2010 4:36:18 PM • HP DeskJet... • Answered on Sep 12, 2010
HP DeskJet 970cse InkJet Printer Logo
59 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
printer tries three times
  • Office Equipment & Supplies
