20 Most Recent Toro 2-Cycle 25.4 cc Power Head 51944 Questions & Answers
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
9/3/2016 1:23:44 PM • Toro 2-Cycle... • Answered on Sep 03, 2016
Repair pull cord
http://www.ereplacementparts.com/recoil-starter-asm-p-1527410.html
6/3/2016 12:24:26 PM • Toro 2-Cycle... • Answered on Jun 03, 2016
0answers
0answers
What is the high altitude adjustment required by the manual?
the high speed adjustment needs to be richened up to compensate for the lean air mixture at high altitude. it can run but will run fast and may damage the unit because it is lean. the high speed adjustment is the one marked H or the screw farthest from the engine. turn it counter clockwise while running at full speed until it runs at the correct RPM. any small engine repair center should be able to do this for you and keep you from causing irreparable damage If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
3/4/2013 11:24:01 PM • Toro 2-Cycle... • Answered on Mar 04, 2013
2answers
Toro CCR 2450 Snowblower has new plug & gas but will only start with added starter fluid then will run until trying to start again.
Question edited for clarity. When you put it away at the end of last snow season, I expect you just rolled it to the corner of the garage and left it until now? The two stroke gas in the carburetor, went bad and gummy. It starts on starter fluid because no gas is coming from the carb. https://www.google.com/search?q=toro+ccr+2450+carburetor+cleaning ..
1/20/2024 9:51:29 AM • Toro Garden • Answered on Jan 20, 2024
We have a Toro Powervac that will not start. Vac has a new carburetor, new engine coil, new fuel lines, new spark plug and still will not start. Any suggestions?
did you make sure it has spark. i have learned over the years because an electronic is new doesn't mean its good? If it has spark remove the plug and put a bit of gas in the hole and re install plug see if it will fire on that gas. if it does its the carb something is probably blocking fuel. check the compression if its low compression it will not run. if u dont have a compression checker just remove the plug stick your finger tight over the plug hole and pull it over it should blow your finger off the hole.
9/17/2023 6:54:34 AM • Toro Garden • Answered on Sep 17, 2023
Hi, I would like to know what is the typical compression value of a Kohler 16HP singel cylinder engine?
Yes, decompression lowers cylinder pressure during low rpm while cranking. If you're concerned with compression, you need to do a leakdown test. Inexpensive (~$30) units are available through numerous eVendors. The leakdown test provides a metered volume of air that is translated and displayed on a pressure gauge simply labeled high (excessive leakage), moderate, or low (nominal leakage).
It's an L-head engine and once they get a few hundred hours run time, the valves wear into the hard seat, lash goes to zero, and they become hard to start. You can check valve lash by removing the crankcase breather (two screws). If lash is near zero, time for a valve job. Plenty of how to videos on the web. If it's easy start, just low power then less likely a valve lash issue.
There are many things that cause low power. Bad fuel, water in fuel (fuel bowl), fouled carburetor, poor spark, fouled plug, improper plug gap, wrong plug, weak ignition module.
9/12/2023 10:24:23 AM • Toro Garden • Answered on Sep 12, 2023
Toro riding mower stopped moving
If you have no forward, no reverse but the motor is still running normally the most likely reason for this is the main drive belt. This connects the motor to the transmission. If it stretches, breaks or drops off the drive pulleys you will lose all movement.
8/21/2023 3:49:43 PM • Toro Garden • Answered on Aug 21, 2023
Why does my Toro Titan HD 2000 series 74467 blow a fuse every time I engage The blade?
My thought is the seat safety switch is faulty, because normally these mowers won't work unless someone is sitting in the seat when if goes into the blade drive. There are other ideas in the videos. Frayed wires in the harness somewhere?
4/29/2023 6:19:25 PM • Toro Garden • Answered on Apr 29, 2023
I have an electric Toro 1500 Power Curve snow blower and it makes a high pitch squeal when I turn on the blower. Possible bearing issue?
Yes, a high-pitched squeal coming from your electric snow blower when you turn on the blower could indicate a bearing issue. The blower motor is typically equipped with bearings to reduce friction and allow the motor to run smoothly. Over time, these bearings can wear out or become damaged, resulting in a squealing or grinding noise. If you suspect a bearing issue, it's important to have your snow blower inspected and repaired by a qualified technician or service center. Attempting to repair the snow blower on your own could be dangerous and may cause further damage to the machine.
3/9/2023 3:02:46 PM • Toro Garden • Answered on Mar 09, 2023
Toro 2-Cycle 25.4 cc Power Head 51944 Logo
17 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
  • Garden
