20 Most Recent
HP Printer/Scanner/Copier 2210 Ink-jet Printer Questions & Answers
HELP!
use a GENUINE cartridge
3/28/2010 6:24:25 AM •
HP...
Answered
on Mar 28, 2010
My printer wont print
have you turned it on? i know this may sound obvious but Wow theres a lot of information in that question. Thought long and hard
about what you wanted to ask huh?
2/3/2010 11:36:07 PM •
HP...
Answered
on Feb 03, 2010
The display says remove and check cartridge. i
I am forwarding inforamtion that I know plus some information that you can find on the HP website and can be helpful to you.
1.Remove both the ink cartridges from the printer and clean the cartridge contacts on the printer using soft cotton cloth dipped in distilled water.
2.Also connect the printer directly to the wall jack if connected to surge protector. Now turn off the printer and again turn on. When the printer prompts to insert the ink cartridges, Insert them to the printer.
3.If the issue persists, download the firmware patch from the below link :
ftp://ftp.hp.com/pub/softlib/software3/COL4324/oj-14039-3/HpAiOFWUpdate2_2.exe
4.
NOTE : Ensure that printer is connected to the computer and also turned on while you install the patch.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
1/7/2010 12:28:47 AM •
HP...
Answered
on Jan 07, 2010
Will not fax out, or receive faxes
Check the FAX cable and make sure it is a FAX cable. There should be only 2 gold
contacts when you look at the cable jack. Phones use a 4 contact cable.
5/27/2009 5:11:39 PM •
HP...
Answered
on May 27, 2009
Hp psc 2210 all-in-one
My computer will not allign right. It says paper is too narrow...insert wider paper...then refuses to do task . All the paper is the same. It is not the paper. What do I do?
4/3/2009 12:30:29 AM •
HP...
Answered
on Apr 03, 2009
Hp laserjet printer 3052 Scanner error 2 turn off and then turn onn
The "Scanner error 2" message on an HP LaserJet 3052 printer typically indicates a problem with the scanner assembly. To resolve this issue, you should turn off the printer, unplug it from the power source, and wait for a few minutes. Then plug the printer back in and turn it on again. This will often clear the error and restore normal operation of the scanner. If the error persists, you may need to contact HP technical support for further assistance.
1/19/2023 4:55:23 PM •
HP Office...
Answered
on Jan 19, 2023
Hp color laserjet 4700 printing with shadows
If your HP Color LaserJet 4700 is printing with shadows, it could be caused by a few different issues. Here are a few potential causes:
- Toner Cartridges: The toner cartridges may be low or empty, causing the shadows to appear. It is recommended to check the toner levels and replace the cartridges if necessary.
- Toner Smears: The toner smears on the drum or the fuser can cause shadows to appear on the printouts. Clean the drum and fuser with a lint-free cloth and check if the problem persists.
- Fuser Unit: The fuser unit could be malfunctioning and may need to be replaced.
- Paper Quality: Using low-quality or damp paper can cause shadows to appear on the printouts. Use high-quality, dry paper for better results.
- Printer settings: Some printer settings can also cause shadows to appear, such as toner density or print resolution. Ensure that the settings are set to the recommended level.
- Dust or debris: Dust or debris inside the printer can cause shadows, Clean the inside of the printer and check if the problem persists.
It is important to diagnose the specific cause of the problem before attempting to fix it. If you are not comfortable with troubleshooting the problem, it is best to contact HP support or a qualified technician for assistance.
1/12/2023 12:08:51 PM •
HP Office...
Answered
on Jan 12, 2023
What does Error message 50.2F.00 mean?
The error message "50.2F.00" typically refers to a problem with the fuser assembly in an HP LaserJet 500 color M551 series printer. The fuser assembly is responsible for fusing toner to the paper, and this error can occur if the fuser is not functioning properly.
There are a few potential causes for this error message:
- The fuser may not be properly installed in the printer, in which case you should check to make sure that it is securely seated and connected.
- The fuser may be defective, which is most likely the case if the error message appears shortly after installing a new fuser. In this case, you may need to replace the fuser with a new one.
- There may be a problem with the printer's power supply, which is causing the fuser to malfunction. You should check the connections and ensure that the power supply is working properly.
It is also good idea to check for any firmware updates for your printer. Sometimes these updates can fix known issues.
The best thing to do is check the printer's manual for troubleshooting or HP Support for specific instructions for your printer. Also you can try to call the manufacturer support.
1/10/2023 4:02:07 PM •
HP Office...
Answered
on Jan 10, 2023
Ink reset HP J6410
Unfortunately, you cannot reset the HP 74-75 ink cartridge ink level monitoring feature once they are empty (either refilled, remanufactured or compatible ink cartridges)...however print operations are still permitted. Watch this 'Low Ink Warning video' for all printer models which use the HP 74-75 ink cartridges:
HP 74, 75, 74XL, 75XL Cartridge Refills - Solving Errors
& Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
Diagnostic Tap 41 Test (verifies electrical health of ink
cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
NOTE:
To access the diagnostics menu on the HP Officejet J5700 or J6400 series
printers, select * and # keys simultaneously and enter 124 (or 123). From there
you can access the Reports Menu, 'print-mech tap test and run the diagnostic code=41
test (see video above for reference) - this will tell you the exact health of your ink
cartridges. To run it I think you'll need to access via '124' access code for the HP OJ J64xx printer series. For more information, please visit:www.inkjet411.com
1/10/2023 6:17:23 AM •
HP Office...
Answered
on Jan 10, 2023
Hp laserjet m404 no display
please ensure that your printer is not overheating from extensive operating first. If so, please it off for 30 minutes before using the printer again. If you have any external usb drives attached to the printer, please remove them, restart the printer via the power button and check the display again. If all else fails, you might need to factory reset your printer to be able to overcome this issue.
Thank you.
1/8/2023 7:24:59 PM •
HP Office...
Answered
on Jan 08, 2023
My hp 4315 all in one works but copier comes out blank
There could be several reasons why the copier is producing blank pages. Here are a few possible causes:
- The ink or toner cartridges are empty or low. Make sure you have new cartridges installed, or try replacing the old ones to see if that fixes the issue.
- The scanner bed or the glass surface is dirty. Clean the scanner bed and glass surface with a soft, lint-free cloth to remove any dust or debris.
- The paper tray is empty or has malfunctioning paper. Make sure there is paper in the tray and that it is not wrinkled or damaged.
- The printer drivers are out of date or corrupt. Try updating the drivers to see if that fixes the issue.
If none of these solutions fix the problem, there may be a more serious issue with the printer that will require professional repair. In that case, you can try contacting HP customer support for further assistance.
1/6/2023 8:11:27 PM •
HP Office...
Answered
on Jan 06, 2023
MY HP LASERJET 200 ONLY PRINT THREE COLORS WHY?
please ensure that all of the cartridges are created by HP and not a 3rd party developer. If not, the HP firmware would stop that one cartridge from printing. Also, you can ensure that the color that's not printing isn't empty. Otherwise, you can check that each color cartridge is properly installed and then restart the printer before moving forward.
Thank you.
12/31/2022 8:03:51 PM •
HP Office...
Answered
on Dec 31, 2022
My HP Photosmart will not print pictures
There are a few possible reasons why your HP Photosmart printer may not be printing pictures, particularly if it is able to print an 8x10 size but not a 4x6 size. Here are a few things you can try to troubleshoot the problem:
- Check the printer settings: Make sure the printer is set to the correct paper size and print quality settings for the type of pictures you are trying to print. If the settings are not appropriate for the size or quality of the pictures, it can affect the print quality and cause the printer to display an error message.
- Check the paper tray: Make sure the paper tray is correctly aligned and has enough paper to accommodate the size of the pictures you are trying to print. If the paper tray is not properly aligned or is empty, it can cause the printer to malfunction.
- Check the ink cartridges: Make sure the ink cartridges are properly installed and that there is enough ink. If the cartridges are low on ink or not properly installed, it can cause the printer to display an error message or produce poor print quality.
- Check for any visible issues: Inspect the printer and its components for any visible issues that may be causing the problem. This can include debris or foreign objects that may have gotten stuck in the printer, or damage to the printer or its components.
If you have tried these troubleshooting steps and the problem persists, it is recommended to have the printer serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
I hope this information is helpful. If you have any further questions or need additional assistance, please don't hesitate to ask.
12/26/2022 12:56:04 AM •
HP Office...
Answered
on Dec 26, 2022
My hp designjet 500 new printhead not support and not aliment what can i do?
If your HP Designjet 500 is not detecting the new printhead, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
- Check the printhead connection: Make sure the printhead is properly connected to the printer. If the printhead is not securely installed, it may not be detected by the printer.
- Check the printhead compatibility: Make sure the new printhead is compatible with your HP Designjet 500 printer. Using a printhead that is not compatible with your printer can cause issues with the printhead being detected.
- Check the printer firmware: Make sure the printer's firmware is up to date. If the firmware is out of date, it may not be able to recognize the new printhead. You can check for updates by going to the HP Support website and downloading the latest firmware for your printer.
- Check for any visible issues: Inspect the printhead and the printer for any visible issues that may be preventing the printhead from being detected. This can include debris or foreign objects that may have gotten stuck in the printhead or printer, or damage to the printhead or printer.
If you have tried these troubleshooting steps and the problem persists, it may be necessary to have the printer serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
12/26/2022 12:02:43 AM •
HP Office...
Answered
on Dec 26, 2022
