20 Most Recent HP LaserJet 3300 All-In-One Printer Questions & Answers
You will need to install the software from HP support if you do not have a disc. The link should put you on the right track
https://support.hp.com/us-en/product/hp-laserjet-3300-multifunction-printer-series/66359/drivers
HP LaserJet 3300... | Answered on Mar 07, 2018
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
HP LaserJet 3300... | Answered on Dec 05, 2017
There's a narrow window above where the drum sits that gets covered with toner, wipe it with a soft cloth, also check if the image in the blurred area wipes off which means something could be wrapped around the fuser roller. Inspect the drum too, if you see a dark band where the blurrs are, you need a new drum.
HP LaserJet 3300... | Answered on Sep 27, 2015
Hopefully this will help you. Good luck !
Causes of jams
NOTE If you are experiencing jams in the duplex paper path, make sure that the duplex-tray
lever is set to the correct media size for your country/region. Open the duplex-paper-path door
and look at the embossed arrow on the lever. Make sure that it points to the media size for your
country/region. If the size needs to be changed, push the lever all the way in for duplex printing
on letter- and legal-size media, or pull it all the way out for duplex printing on A4-size media.
A4
LTR,
LGL
A4
LTR,
LGL
Occasionally, paper or other print media can become jammed during a print job. Some causes include
the following events:
? The print media that is being used does not meet HP specifications.
? The media is damaged or has objects attached to it, such as staples or paper clips.
? The environment in which the print media was stored is too humid or too dry.
? The input trays are loaded incorrectly or overfilled, or the media guides are not set correctly.
? Too many sheets have accumulated in an output area, or sheets are blocking an output area.
? Media is added to or removed from an input tray during a print job or an input tray is removed from
the all-in-one during a print job.
? The cartridge door is opened during a print job.
ENWW
HP LaserJet 3300... | Answered on Jul 02, 2015
Model number wrong...pl check.
HP LaserJet 3300... | Answered on Feb 16, 2013
Hello and Welcome to FixYa!
Try reseting the printer, its an ink system failure message.
Step are mentioned here.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
HP LaserJet 3300... | Answered on Feb 20, 2011
Start here:
HP LaserJet 3300 Multifunction Printer series support pages
You can download the drivers and software for your printer from here:
Download drivers and software . Select your software/driver language and operating system to see all available downloads for your system.
HP LaserJet 3300... | Answered on Oct 01, 2010
You can download the software from HP on the link below. If that does not work you can call them and they will send you the cd for the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=72628&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=66359
Good Luck
HP LaserJet 3300... | Answered on Aug 21, 2010
Your previous driver was supplied via HP, and incorporated the Scan To PDF in it.
Unfortunately, the driver for Win7 is through Windows 7 (not HP), and doesn't have this capability.
To mimic what you had before, you can install Adobe Acrobat, and set it to watch a folder for new files (Distiller). When it finds one, it will convert it to PDF automatically. But, Adobe costs $.
There are a number of utilities on the internet (google for convert tif to pdf) which can make the pdf files for you, but it will still be an extra step.
HP LaserJet 3300... | Answered on Jun 28, 2010
Have your phone company run a test on the line. This is usually the problem. If they determine that your line is good, then check the phone cord. It could be bad or even plugged into the wrong port.
HP LaserJet 3300... | Answered on Jun 25, 2010
here's the link to your printer driver
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=72628&prodTypeId=18972&prodSeriesId=66359&swLang=8&taskId=135&swEnvOID=228
HP LaserJet 3300... | Answered on Mar 08, 2010
go to www.hp.com, select all-in-one and browse to your printer. then select the respective operating system and download.
HP LaserJet 3300... | Answered on Jan 25, 2010
Try doing a reset by holding down the * and Menu/Enter keys while plugging in the unit, hold the keys down until the screen says that it is resetting.
The 3300 also has a "Secret Menu" that can be accessed by;
To View The Secret Menu:
1: Press Both The Left And Right Navigation Arrow Keys
2: It Will Ask You To "Enter A Special Key Combo.", Enter "123" (Without Quotes)
3: You Should Be In The Secret Menu Now.
P.S. Use The Arrow Keys To Navigate.
The manual can be found at;
http://www.fixyourownprinter.com/reference/manuals/public/hp
Hope this helps!
HP LaserJet 3300... | Answered on Dec 09, 2009
HP LaserJet 3300 All-In-One Printer Logo
39 questions posted
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laser jet 3300 constant noise
  • Office Equipment & Supplies
