20 Most Recent Ryobi Lithium Ion 18 Volt 18v Cordless String Trimmer Edger Weedwacker P2002 Questions & Answers
Ryobi Trimmers unscrew halfway down the shaft (so it fits in the box). If this gets loose, the trimmer will stop working. Simply tighten the connection between the upper and lower half.
Ryobi Lithium... | Answered on Mar 23, 2020
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Ryobi Lithium... | Answered on May 14, 2019
On the WEB, maybe they can help:
Cordless String Trimmer Edger‎
Adwww.worx.com/‎
Ryobi Lithium... | Answered on Apr 26, 2018
have you read your operators manual.? They generally just unclip and pull out.
Ryobi Lithium... | Answered on May 25, 2016
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Ryobi Lithium... | Answered on Jul 18, 2015
it might be that your battery need changing even though the machine is lightly used the battery might have aged prematurely.
Ryobi Lithium... | Answered on May 28, 2015
Check to make sure you don't have a staple stuck under the hammer. If the spring feed is working, then something is keeping the staples from sliding under the hammer. Can you hear the hammer hitting? Does it leave an impression on the wood?
Ryobi Lithium... | Answered on Jul 30, 2014
Make a sharp bend in the line and insert it into the hole in the spool hub. Start wrapping the replacement line in the direction shown on the spool.
Ryobi Lithium... | Answered on Jul 27, 2014
full throttle, tap on ground, line should feed automaticaly.
Ryobi Lithium... | Answered on Jul 24, 2014
the wiring maybe disconnected, either at the switch or down near the head of the trimmer
Ryobi Lithium... | Answered on Nov 26, 2013
Ryobi Lithium Ion 18 Volt 18v Cordless String Trimmer Edger Weedwacker P2002 Logo
20 questions posted
Top Ryobi Garden Experts
Nick Olsen
bryan st
Tim Venetis
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
View Most Popular
Ryobi Garden
  • Ryobi Garden
Most Popular Question
electric ryobi weedeater good battery
  • Garden
