20 Most Recent HP DeskJet 3740 C9026A Printer Questions & Answers
unplug the cable from the computer to the printer, make sure you got all of the jam out. Unplug the power from the wall wait a few seconds and plug back in. (with usb cable still unplugged)Then try deleting all documents from the que. If the machine is in the ready mode, (green light on) plug usb cable in and try again. Let me know if this solves you problem. If not we can try a few other things.
HP DeskJet 3740... | Answered on Jun 29, 2007
check it`s sensor
HP DeskJet... | Answered on May 15, 2019
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
HP DeskJet... | Answered on Apr 23, 2019
1) Open the printer cover and wait till the carriage moves towards the middle.
2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer.
3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward.
4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab.
5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges.
6) Close the printer cover. Connect the power cord at the backside of the printer.
HP DeskJet... | Answered on Nov 28, 2018
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
HP DeskJet... | Answered on Oct 11, 2018
plug it into the wall
plug it into the computer
go to printers ad devices
go to add a printer
install the cd or usb stick
and follow the installer wizard instructions
All in the operators manual for the printer
HP DeskJet... | Answered on Sep 20, 2018
mine only scans when you are at the machine , i suppose that is where you need to be to scan with yours also .
HP DeskJet... | Answered on Apr 24, 2018
www.hp.com/support
enter printer model and number and run diagnostics with your printer connected to your PC or Laptop.
HP DeskJet... | Answered on Feb 22, 2018
2 questions posted
Ekse
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
printer work
  • Office Equipment & Supplies
