20 Most Recent HP DesignJet 5000 InkJet Printer Questions & Answers
The crazy thing likes to test the print heads after each print, any ideas
Hi Garry,Try uninstalling the Printer driver and reinstall it again, then try printing to see if it will still do the same thing with the print head checking.have a great day,mvincentc
4/20/2012 6:24:39 PM • HP DesignJet... • Answered on Apr 20, 2012
2answers
The printer is saying to reseat ink cartridge. I
Did you reset your printer after reseating the cartridge? You may also need to restart it after reseating it.
3/14/2011 2:33:11 PM • HP DesignJet... • Answered on Mar 14, 2011
Why I need to fit 2 or 3 times a year printheads hp desingjet5000
False indications about print head conditions are usually caused by a worn out trailing cable.
4/15/2010 5:31:47 PM • HP DesignJet... • Answered on Apr 15, 2010
tip
Where to find the manual (pdf) for HP Designjet 500 printer
Sometimes , it is convenient to have a soft copy of your user manual. You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please Click Here to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual. I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the above mentioned link.You will be taken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturers website , click on the link below:
Canon USA
Canon Global
HP
Epson
Lexmark
Samsung
Brother
Please rate this tip if you found it useful.
Kind Regards
StephanSA
I need a printer driver for hp designjet 5000ps os vista.
If you google " hp printer drivers" it will take you to there home site and you can put your model # of your printer and it will give you 4 diffrent design jet 5000 printer drivers.all you will need to do is pick the model that you have and it will dowload it for you.i already checked for you to make sure..
5/17/2009 12:08:26 AM • HP DesignJet... • Answered on May 17, 2009
Hi Hp designjet t520 printer when i print the reportthe cyan color change his place with magenta color and yellow is dark thanks i need to help
check the catridges thier must be a mixing up of color when you were refilling the catridges
3/15/2022 4:11:23 PM • HP DesignJet... • Answered on Mar 15, 2022
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
5/8/2020 3:49:18 PM • HP DesignJet... • Answered on May 08, 2020
HP Designjet T3500 Ethernet port not working
To solve issues visit https://support.hp.com/in-en/document/c04530811 to get quick support call our Toll-Free 1 888 224 4280
7/30/2018 5:24:16 AM • HP DesignJet... • Answered on Jul 30, 2018
How do I bypass the expired cartridge on a HP DesignJet T610?
The dates are on the package for a reason. The ink dries out or changes viscosity over time and will likely clog the printhead. My advice is not to stock up on cartridges because of this problem. If you look online, you can find replacement chips or instructions on how to reset the chip on the cartridge.
4/15/2015 5:28:53 PM • HP DesignJet... • Answered on Apr 15, 2015
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer: A.- Using the control panel B.- Using the web server C.- Using the Jet Admin Utility We'll deal with the contro panel setup. To access the contro panel menus 1. Press OK (Check Mark) button once to access MENUS. 2. Press Up Arrow or Down Arrow buttons to navigate the listings. 3. Press OK (Check Mark) button to select the appropriate option. 4. Press Return to return to the previous level. 5. Press OK (Check Mark) button to exit the menus So to configure IP address: Press Check Mark Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows) Navigate to the I/O Menu Navigate to the EIO 1 menu Navigate to TCP/IP Navigate to BootP entry Press Check to disable it (Off) Press return Navigate to IP Address, press Check Use Up/Down buttons to change the address, check to move between octets. When finished, press Return In the same way, enter Mask and Default Gateway Press Return until you are out of the Menus. Done
7/30/2014 5:40:47 PM • HP DesignJet... • Answered on Jul 30, 2014
0answers
Reset HP T790
Be the first to answer 5/26/2014 6:15:00 AM • HP DesignJet... • Posted on May 26, 2014Be the first to answer
Smudges on HP5100 using PP white paper
If this is an HP LaserJet 5100, then the cartridge or the fuser need to be replaced.
4/16/2014 1:02:43 AM • HP DesignJet... • Answered on Apr 16, 2014
Hp designjet 70
run "clean heads" or replace color catrige.
4/14/2014 5:14:07 AM • HP DesignJet... • Answered on Apr 14, 2014
HP DesignJet 5000 InkJet Printer Logo
6 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
crazy thing likes test print heads after
  • Office Equipment & Supplies
