20 Most Recent
HP PhotoSmart 7150 InkJet Printer Questions & Answers
My printer worked on 12/31/2010 but on the
is
this a networked printer? if so, your router may have assigned it a new IP
address, and your computer cannot find the printer. Use the keys on the printer to find the IP address in the
printer settings, and then update the IP address for the printer port in
your computer.
My photosmart 7150 prints half a page(vertical
Ok, I was having this same problem and the solution for me appears to lay in the fact that the "photo tray" was pushed in, signaling to the printer that it should print to the size specifications of a photo (approximately half the width of a standard letter page).
I should also mention that with my problem, the printer would hang at every single print job--presumably to wait for you to input your photo paper--and that executing this fix solved the problem.
To fix this, I followed these instructions:
SOLUTION:Follow the steps below to correct the issue:
- Disconnect power to the printer.
- Remove all photo paper from the Photo Tray.
- Push the Photo Tray completely into the printer.
- Snap the Photo Tray out (towards you) sharply.
- Reconnect power to the printer.
- Print a self-test on 8.5 X 10 paper.
- Engage the Photo Tray.
From the Printer Toolbox, select Calibrate the Photo Tray .
Print cartridge cradle cannot move.
Please perform this reset or its a hardware failure
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by following these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord.
