20 Most Recent HP LaserJet 3320mfp All-In-One Printer Questions & Answers
Hi
restart you printer
HP LaserJet... | Answered on Nov 19, 2010
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
HP LaserJet... | Answered on Dec 02, 2007
thisis the farmetter problem
HP LaserJet... | Answered on Nov 11, 2019
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
HP LaserJet... | Answered on Oct 07, 2019
I have face a problem in laserjet m1136 i.e. show a e8 error .how can i free it or remove it..
HP LaserJet... | Answered on Oct 03, 2019
bad toner cartridge. Probably black
HP LaserJet... | Answered on Aug 28, 2019
To select the default language on the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Control Panel Setup], and then press the [OK] button.
More items...
SOLVED: Change language from german to english on p3015 - Fixya
www.fixya.com/support/t12816917-change_language_from_german_english
change the language on HP laserjet 3015 printer Google Search
HP LaserJet... | Answered on Jul 16, 2019
Guys, its easy.. I found a little piece of paper after seeking calmly. It was on the paper pulling system when collecting from the tray. See the pic, it was right whee i'm pointing with my tool. It was locking one of the sensors around there. See in the third image where my tool is pointing.. Its exactly inside and very difficult to see.. And one more thing.. You'll have to unscrew the upper cover to see it.. Good luck
I love smart gadgets like this. Easy to solve. 1d69ed0c-5731-4c6b-ae7c-d49ff90e96d8.jpg 8e1e42b8-3851-411a-98e1-09eb08d019b9.jpg dd6af869-4bf3-4193-af33-57d2d362752b.jpg
HP LaserJet... | Answered on Jun 30, 2019
Go to printer driver make sure you've have legal selected
HP LaserJet... | Answered on May 21, 2019
Need more info. What exactly is happening when that error occurs? ie.. the print job starts and paper feeds through then the error pops up? etc.?
HP LaserJet... | Answered on May 16, 2019
Scanner Error 22
Is it all the colors? Make sure the drum shutters open and close when opening and closing the front door. Missing magenta color is common in this machine and other machines like it. The magenta laser scanner mirror sits in the lower part of the printer and face up and toward the front of the printer. Loose toner from printing tends to settle on this mirror. Over time the mirror coats over and the actual laser scanner beam cannot reflect off the mirror with proper intensity, usually resulting in very faded magenta color or no magenta at all. Good luck
HP LaserJet... | Answered on Apr 20, 2019
HP LaserJet 3320mfp All-In-One Printer Logo
3 questions posted
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
scan head carriage not parking in one
  • Office Equipment & Supplies
