20 Most Recent HP LaserJet 4p Printer Questions & Answers
Why is my canion ir 2018 making blank copies
you coppier laser scaner unit or hi voltage power supply complaint
7/3/2014 10:43:46 PM • HP LaserJet 4p... • Answered on Jul 03, 2014
How do I find the scanner unit, hp4mv
usually found just under top cover.
4/15/2014 1:11:44 AM • HP LaserJet 4p... • Answered on Apr 15, 2014
Connecting with usb port
try a usb/Parallel Printer Adapter Cablecable you can find them at office supply stores or others such as walmart.http://www.walmart.com/ip/15075022?adid=22222222227000586714&wmlspartner=wlpa&wl0=&wl1=g&wl2=&wl3=21486607510&wl4=&wl5=pla&veh=sem
12/16/2012 6:35:40 PM • HP LaserJet 4p... • Answered on Dec 16, 2012
2answers
Well, I did everything your
If your printer makes a load clicking sound and then shows "paper jam" then the problem is a broken drive motor gear. This is a very common problem with this unit. The nylon gear on the drive motor becomes brittle due to the age of the unit and cracks. When this happens the gear teeth do not mesh with the other gears and you get the grinding and clicking sound, and no paper pickup. You can change the gear yourself. The drive gear is available here:http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61And here is a video showing how to install it:
7/20/2012 6:24:47 PM • HP LaserJet 4p... • Answered on Jul 20, 2012
My older hp Laserjet 4P
Hi
You can try turning off the "Enable bidirectional support" in Ports option.
However this could be attributed to a corrupt PostScript file (or a regular file being printed through a PostScript driver). Usually PostScript files print just fine, but in some rare cases the file might contain corrupt PS instructions, and the printer will not print it correctly, so the print server keeps sending the file to the printer over and over. Unfortunately there is no way to detect that the file is corrupt before printing. The best solution is to monitor the print job while it is being printed. If you find that the job is being printed again and again, you need to cancel the job. To cancel it, double click on the printer icon (under Printers & Faxes folder) and then delete the problematic job. Or under UNIX, use the lpq command to list the current jobs in the queue, locate your job number (should be the active one), and use the lprm command to remove your print job.
Also try this because it is working for me now trash this file com.apple.print.printerproxy.hplaserJet1012.plist from your Users - Computer Name - Library - Preferences folder and that should fix it along with removing and re-adding your printer in the Print & Fax setup box.
Please get back to us if you have further query else please accept the suggestion.Thank you for contacting fixya.com
5/5/2011 6:00:12 PM • HP LaserJet 4p... • Answered on May 05, 2011
HP 4P band of grey
hi
very simple
Use the following troubleshooting steps to resolve this issue:
  1. The print cartridge is almost empty. Shake the cartridge gently to redistribute the toner, or replace the print cartridge.
  2. The print cartridge may be damaged. Replace the print cartridge.
  3. The printer's internal mirror may be dirty. Lift the print cartridge access cover, remove the brush from the underside of the cover, and clean off the mirror using the brush.
  4. use p/n 92274A for toner replacement
please issue 4 thumbs up
thanks for using FIXYA
4/5/2011 12:43:45 AM • HP LaserJet 4p... • Answered on Apr 05, 2011
Right side of page printing is broken up
Open the back cover and check out the fuser rollers
12/14/2010 6:28:58 PM • HP LaserJet 4p... • Answered on Dec 14, 2010
3answers
On a LaserJet 4P It's been working fine for
Uninstall, reboot then reinstall the software/driver
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
6/9/2010 6:59:51 AM • HP LaserJet 4p... • Answered on Jun 09, 2010
Just got a new computer. Have an old HP Laserjet
you have to refer to usb/ parallel converter manual, not printer manual
4/8/2010 6:17:16 AM • HP LaserJet 4p... • Answered on Apr 08, 2010
When printing a page. I get a large shaded area
umm
you may know that this model of printers is very old
i think your cartridge is expiered try to change the cartridge if by the old one just to test....
if the new cartridge is the reason then you have to replace it
2/19/2010 6:13:37 PM • HP LaserJet 4p... • Answered on Feb 19, 2010
I have a HP laserjet 4P. The print was coming out
You need to replace your transfer roller. Might as well do a complete maintenance kit.(Rollers, Fuser and Transfer Roller)
11/9/2009 4:48:09 PM • HP LaserJet 4p... • Answered on Nov 09, 2009
2answers
Printing or doing a test print. very lite print.allso no print
few things to consider:
1. You might be running out of ink from the cartridges. Try replacing.
2. You can clean the printer head for some clogged nozzle.
3. Check your printer settings if it was set to grayscale.
7/30/2009 8:52:59 AM • HP LaserJet 4p... • Answered on Jul 30, 2009
The printer was printing several pages, then
It sounds like the fuser gears are broken, that happens with paper jam sometimes from all the heat of the fuser. A new fuser will probably run around $100.00 for that machine.
7/14/2009 8:49:19 PM • HP LaserJet 4p... • Answered on Jul 14, 2009
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
4/16/2009 7:13:03 PM • HP LaserJet 4p... • Answered on Apr 16, 2009
Printing on my HP 4P Lazerjet produces shading on the left side
Most likely you need to put a transfer roller and a fuser in.
2/17/2009 12:10:31 AM • HP LaserJet 4p... • Answered on Feb 17, 2009
Windows vista does not seem to recognize HP 4P printer
WOW!? HP4P... I don't think you'll find a Vista Driver for that printer.
Try www.hp.com in the downloads section.
Good luck from a crusty old HP Printer Tech.
1/23/2009 10:19:28 PM • HP LaserJet 4p... • Answered on Jan 23, 2009
How do you replace the fan on HP LaserJet 4P
Removed cover - found foam filter was hitting fan blade causing an error code of 58 to appear.
1/9/2009 5:06:17 PM • HP LaserJet 4p... • Answered on Jan 09, 2009
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
2/29/2008 8:18:05 PM • HP LaserJet 4p... • Answered on Feb 29, 2008
HP LaserJet 4p Printer Logo
27 questions posted
Ben Johnson
Marvin
Marvin
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
connecting usb port
  • Office Equipment & Supplies
