20 Most Recent HP LaserJet 2430 Printer Questions & Answers
If the paper jam error first occurs just after you have replaced the toner cartridge (as it did for me), carefully look inside (with toner cartridge removed) near the rear at the fuser and there may be a black piece of paper sticking out and/or curled up against the back. I needed a flashlight to see it but still wasn't sure until I felt around and found it. It was the protective sleeve that was around the drum in the toner and when I replaced the toner I missed it. When I first powered up the printer, the sleeve got fed partially into the fuser and the tail curled up against the back, making it practically invisible. Also, with that jam, the printer made no motor or gear train noise at power on so it almost had me convinced that the motor was bad. After removing the black piece of paper, the printer initialized normally.
HP LaserJet 2430... | Answered on Mar 06, 2017
The process is changed during SAVE AS function. You can set to save into a folder, and in which format (.jpg, .pdf, etc.).Use the desktop application, tons easier than the printer interface.
HP LaserJet 2430... | Answered on May 19, 2016
Tray 2 should be the one on the bottom and you should be able to put your fingers under the middle section and pull it out.
HP LaserJet 2430... | Answered on Jun 25, 2014
Using the HP Toolbox
HP Toolbox is a Web application that you can use for the following tasks:
? Check the printer status.
? Configure the printer settings.
? View troubleshooting information.
? View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when it is connected to the network. You must perform a complete software installation in
order to use the HP Toolbox.
HP LaserJet 2430... | Answered on May 28, 2014
problem is not the printer, but a settings on the computer
HP LaserJet 2430... | Answered on Apr 30, 2014
just replace the cartridge...
HP LaserJet 2430... | Answered on Jan 02, 2014
Depends how much you are using it. Typically the printer will warn you when it is low. Also you can print a supplies page from the printer menu to see how much toner you have left.
HP LaserJet 2430... | Answered on Jun 12, 2012
Press menu button, scroll to tray behavior, in that select type of paper, default tray & paper size etc..
HP LaserJet 2430... | Answered on Feb 02, 2012
Fist step check with new cartridge, clean transfer roller, clean Laser scanner assembly, check fuser..
HP LaserJet 2430... | Answered on Sep 08, 2011
HP LaserJet 2430 Printer Logo
80 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp 2430 paper jam 13 20 00 find
  • Office Equipment & Supplies
