20 Most Recent
HP LaserJet 5000gn Printer Questions & Answers
Printer prints 1 page and gives an empty one after that unexpected paper size
1.Check paper sizes, if its same as what paper you are using..2. Clean paper path sensors, if these are dusty paper not sensing properly while paper travels, result paper mismatch.Do this exercise If you are not tech guy: Remove cartridge, lift registration assm plate blow air with vacuum cleaner, as well as tray1 area,tray2 area.. Best of luck..
I have a HP Color
I've worked on these printers for years and I never heard of a "duplex transfer belt".
Sounds like you broke a wire or missed plugging in a connector.
Probably a bad Duplex Feed Drive assembly or bad DC Controller.
What is bad duplexer connection?
duplexer is the bit that turns the sheet of paper over to enable it to be printed on its other side. Its usually a tray that the sheet is fed into after its been printed on its 1st side, then out of again to effect the flip and print on the sheet's other side. Its probably a 'bolt-on' option to the printer and may not be seated quite right, so not all its connections are making good contact. Careful, though
as there are high voltages present inside the printer....switch it off and disconnect the mains lead before you go investigating the internals!
Regards
nicam49
HP laserjet 5000gn when i
If by smearing you mean the print is also rubbing off? Then you definately have a fuser unit issue. The fusing unit is the assembly that heats up and "fuses" the toner onto the page. When these start to go bad, usually on one edge or the other the print will smear/double image/wipe off of the effected area. One test you can do to verify a fuser problem is to print a page and then when the page is about half way thru the prcess, shut the printer off. Open the top and remove the toner cartridge, pull out the page and see if the lower part is not smeared. Basically what your checking is to see if the print is ok BEFORE it goes thru the fuser. Based on your description I would suspect your fuser is going bad.
Good Luck and Thank You for using Fixya.
My laserjet 5000 gn series printer show error
This error is related to the printer exhaust fan. Check the fan make sure there is nothing obstructing it. Make sure the fan is connected correctly to the power supply. You should see the connector to lower left of the fan. If both check out then replace the fan.
I HAVE HP cm1312nfiMFP all in one printer. The
Are the ADF rollers turning without picking paper, or is it just not running at all? If the former, check the ADF rollers. If they are smooth, then they are worn and need to be replaced. if the latter, check your driver settings. If they are pointing to the ADF, try removing and reloading your print drivers.
Hp laser jet printer 2055 ,52 scanner error how can solve it please
The HP Printer error 52 indicates with scanner. When you see the HP printer error code 52, then follow the steps:
·Turn off the printer
·Wait for 30 seconds and then turn on the printer
·In case the 52 error is still coming up on the printer, then make sure that the Flatbed scanner assembly is replaced
·In case the error is still being shown, the Scanner/Laser assembly may also require replacement.
Find the more HP printer error codes and their solutions. If you need any help to fix the issue contact HP Printer experts.
