20 Most Recent HP DeskJet 9800 InkJet Printer Questions & Answers
Hp deskjet 9800 power and paper out lights flash together
Remove the back jam access cover and see if there is anything in the way. Also, Try removing ink gunk from the resting area. If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
7/25/2021 7:28:33 PM • HP DeskJet 9800... • Answered on Jul 25, 2021
2answers
Tripped over printer cable. Deskjet 9800 won't
Unplug from power source and from power supply and remove a small philips screw driver the screw holding the power supply pack in rear of printer. Examine power supply for cracks, reinstall and try againg.
You may need to replace power supply unit.
7/17/2019 4:04:53 PM • HP DeskJet 9800... • Answered on Jul 17, 2019
HP 9800 printer that is putting a black thin line
It is the print head, change the cartridge.
4/4/2017 3:37:06 AM • HP DeskJet 9800... • Answered on Apr 04, 2017
How can I remove the absorber to clean it? It's not like most inkjet printers, where you can remove the whole print head assembly.
There are a couple of things you can do. The simplest is to scrape as much of the waste ink cake of the sponges with a blade or spoon. Wrap it in plenty of paper and put it carefully in the rubbish/trash bin. The more complex method is to disassemble the machine so you can remove the cleaning station assembly. If you can do that, all you need do is take the cover off the waste assembly and take out the sponges. scrape off the bulk of the waste ink and then wash the sponges. Lots of hot water and RUBBER GLOVES. Clean them, dry them, replace them and put it all back together. You will need to get a long stem small star drive screwdriver to take everything apart.
3/21/2016 3:54:16 AM • HP DeskJet 9800... • Answered on Mar 21, 2016
Dose it cost to get answers to my problem ?
No it doesn't cost.
11/21/2014 3:14:06 AM • HP DeskJet 9800... • Answered on Nov 21, 2014
Hello I need help but I need to no if this require a fee?
I wonder if your ink is running low...? I've had this happen on mine, but can't remember if there was another cause...Maybe try You tube to see if anyone has posted the fault on there...
11/21/2014 3:10:39 AM • HP DeskJet 9800... • Answered on Nov 21, 2014
Where are the print heads on the hp deskjet 9800?
Lift that little lid on the top they should pop up, give it a few seconds to slide over.
9/6/2014 4:00:43 AM • HP DeskJet 9800... • Answered on Sep 06, 2014
Service manual hp 9800
I have an HP 9800 Deskjet that I print heavier self stick vinyl paper. The print comes out wavy. Lines aren't strait and images get blurred. Seems like the rollers might be worn causing it not to pull paper in right and centered.
8/29/2014 3:36:52 AM • HP DeskJet 9800... • Answered on Aug 29, 2014
0answers
0answers
Printer with Amnesia
Mrs. Smith this is a simple configuration problem if you like i could fix it for you free of charge let let me know
1/28/2014 5:49:21 AM • HP DeskJet 9800... • Answered on Jan 28, 2014
I have an HP ENVY 4502 printer. I have tried setting it up as a wireless, and it works for that moment, but the next day I have to start all over. I have set up a static IP address, and again, it wo
Hi Jennifer, Inconvenience regretted, let me see what can I do for you. It looks the firewall rules on your computer Computer might be restricting the access of the printer. I suggest to configure the Firewall on your computer and give full access to the Printer and its software. Since it is a Wireless Network, it might be possible that firewall might be blocking it. Thanks!
1/28/2014 3:46:15 AM • HP DeskJet 9800... • Answered on Jan 28, 2014
HP DeskJet 9800 InkJet Printer Logo
197 questions posted
Clive
Clive
Ben Johnson
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
hp 9800 printer putting black thin line
  • Office Equipment & Supplies
