20 Most Recent HP Color LaserJet 4600n Printer Questions & Answers
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace the separation roller (located in the paper cassette) when replacing these rollers
7/29/2021 11:51:37 AM • HP Color... • Answered on Jul 29, 2021
Very loud clicking sound when printing
Feedroller HP Feed Rollers Printer Parts HP Laserjet Feedrollers You can download a manual from this site. Run the diagnostics which allows you to test individual components one at a time. You could have a bad drum motor or possibly just a noisy cartridge.
9/30/2015 3:29:40 AM • HP Color... • Answered on Sep 30, 2015
Error 51.2k
Lser beam of black error.. remove laser scanner assm.. check motor rotation.. >Jammed or hard rotation..remove motor gently.. lubricated the shaft..fix..Only professionals can perform this activity..
1/31/2012 7:11:16 PM • HP Color... • Answered on Jan 31, 2012
I installed a new router on our small network and
First, make sure your Router is configured for DHCP, and the Printer is plugged into the Router using a Network Cable. Also, make sure the Activity light on your Router is On for the Port that your plugged the Printer into.
Configuring TCP/IP parameters
You can use the printer control panel to configure the following TCP/IP parameters:
  • usage of the BOOTP file for configuration parameters (the default is to use the BOOTP file)
  • IP address (4 bytes)
  • subnet mask (4 bytes)
  • default gateway (4 bytes)
  • TCP/IP connection timeout (in seconds)
Note: Do not disable BOOTP if you will be using RARP or DHCP to configure TCP/IP parameters.
To automatically configure TCP/IP parameters from the printer control panel:
1. Press the Check Mark button to enter the MENUS.
2. Press the Down Arrow to highlight CONFIGURE DEVICE.
3. Press the Check Mark button to select CONFIGURE DEVICE.
4. Press the Down Arrow to highlight I/O.
5. Press the Check Mark button to select I/O.
6. Press the Down Arrow to highlight EIO X (where X = 1, 2, or 3).
7. Press the Check Mark button to select EIO X.
8. Press the Down Arrow to highlight AUTO.
9. Press the Check Mark button to select AUTO.
10. Press the PAUSE/RESUME button to return to the READY state.
Here is your Manual, with more information about Network Configuration:
http://business.fsu.edu/tech/printermanuals/laserprinters/HP4600.pdf I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
6/18/2011 11:06:48 PM • HP Color... • Answered on Jun 18, 2011
My HP4600n uses a parallel cable, but when I look
The parallel cable on the HP 4600n is a smaller C style connection not the typical larger B style. If you ar looking for a parallel cable ask for an A-C cable. So far I have not seen a USB adapter for this size. I would suggest using the Ethernet cable if it is a 4600n.
6/10/2010 4:46:24 PM • HP Color... • Answered on Jun 10, 2010
HP color laserjet 4600 printer remains in calibrating mode
simply, restore your setting to factory setting
3/31/2010 6:31:05 AM • HP Color... • Answered on Mar 31, 2010
HP Color Laserjet 4600 Printer blink when data is
check your user manual to know the blinking code
3/31/2010 6:30:08 AM • HP Color... • Answered on Mar 31, 2010
Hi, I just aquired an HP 4600n color laser
First. Examine the toner cartridges by inspecting the surface of the drum of each color cartridge. Score marks? Replace toner cartridge(s).
Next. for vertical lines from top to bottom, you will want to inspect the fuser real quick to see if the Hot roller is scored or worn or discolored or any adhesives are adhered to roller. Should be perfectly smooth and uniform in color.
Next, do the consumables life page which is in a menu function.
Information --> Supplies Status Page.
This will tell you the life remaining of the image transfer kit (C9724A) as well as fuser unit. These indicators will help you decide if the consumables are the first cause of the print quality issues you are observing.
2/19/2010 7:49:57 AM • HP Color... • Answered on Feb 19, 2010
When printing large powerpoint presentations half
too much data or not enough memory in your printer to support the job.
Also possibly corrupted data in your powerpoint doc.
if you are using PCL version of the driver, download and setup the PS (PostScript) driver from HP.
There are conflicts with printing PDF/Powerpoint docs using PCL driver.
let us know if this helps. Another thing you can try if possible, convert the Powerpoint into a PDF file and then try printing, but select "Print as Image" in the Advanced section of the print options.
2/11/2010 8:59:41 PM • HP Color... • Answered on Feb 11, 2010
DURING PRINTING, WHETHER IN COLOUR or BLACK/WHITE
Need to Clean the Lance located
1/4/2010 11:28:17 AM • HP Color... • Answered on Jan 04, 2010
2answers
How do i connect this printer directly to my
you will be havin a connecting chord...... connect it to the plug and play port or usb port...........it will ask for installation. install the drivers and use your printer
11/3/2009 12:32:17 PM • HP Color... • Answered on Nov 03, 2009
Pcl xl error subsystem: KERNEL
Why not just that the printer is broke?
Please I need a lot more descriptive information before I can help you.
Would you consider sending me the original document and a "Print to File" of the document. I will also need to know where in the printout the error occurs.
I can run it through some of the tools I have and see if I can spot the failure.
Please send the files to; [email protected]. I will let you know I have them and get a quick look at them to see if it something simple.
Don
10/22/2009 3:14:53 PM • HP Color... • Answered on Oct 22, 2009
4answers
I need to configure my
you have 2 options:
1. it is either you install the MAC drivers of the printer to your Mac and the Windows drivers to your Dell and make it work both ways by unplugging or replugging the printer from one computer to another,
or
2. you can get a printserver and connect the printer to that device which will be connected to your network where the MAC and the Dell is connected. This way you can print on both machine without unplug and replugging of the printer.
below are some resources you need.
you can use this device to connect your computers in the network plus the printer.
http://www.apple.com/airportextreme/
extreme is a router, printerserver and a network attached storage in one.
hope this helps, if you need more info, please let me know
9/29/2009 6:54:20 AM • HP Color... • Answered on Sep 29, 2009
I have a HP 4600 series printers that are having
This problem may be an indication of needing the paperpick-up assembly repalced. It is hard to tell without seeing it.
7/7/2009 7:30:22 PM • HP Color... • Answered on Jul 07, 2009
Hp cm4540 how to reset fuser unit
When you replace the fuser unit it will reset automatically
7/29/2021 11:53:00 AM • HP LaserJet... • Answered on Jul 29, 2021
How to change the language settings from chinese to english in hp printer m1218nfs
Press Menu button..one time Press " >" arrow button seven times, Press enter, Again press enter. Go to English language with help of arrow buttons, to save the language press enter..
7/29/2021 11:52:02 AM • HP LaserJet... • Answered on Jul 29, 2021
Cold reset for hp laserjet 3055
cold= hard reset, unplug the machine-- wait 1 minute-- with power off hold down on power button for 1 minute-- plug back in and power up
7/29/2021 11:51:11 AM • HP LaserJet... • Answered on Jul 29, 2021
HP Color LaserJet 4600n Printer Logo
22 questions posted
Vinaya Kumar...
Vinaya Kumar...
Ekse
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp4600n uses parallel cable but when
  • Office Equipment & Supplies
