20 Most Recent HP LaserJet 8100dn Printer Questions & Answers
HP LASER PRINTER 8100, 8150 ERROR 57.5 code
1. The fan 1 or the laser/scanner fan has occurred.
2. Replace fan 1
3. Replace the D.C. controller board.
Try reseating the connector to the fan, it may have worked loose.
HP LaserJet... | Answered on May 19, 2012
for solution, click here
HP LaserJet... | Answered on Jun 29, 2010
Hi
You are getting Error 13.12 due to paper jam at Paper feed 1. It can also happen when the Paper doesn't reach PS2(paper sensor 2).
Please check the picture for more details---
Try printing from Tray 2 or Tray 3, if it fails printing from tray 2 or 3 then Paper sensor 2 (PS2) is bad. To check the movement of flag insert the paper manually in the sensor path.
Remove any paper present in printer and then perform a paper path test using a duplexer. If issue is still not resolved then please remove the duplexer unit and re seat it. After re seating the duplexer your issue will be resolved.
Daniel Scott
HP LaserJet... | Answered on Jun 28, 2010
thisis the farmetter problem
HP LaserJet... | Answered on Nov 11, 2019
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
HP LaserJet... | Answered on Oct 07, 2019
I have face a problem in laserjet m1136 i.e. show a e8 error .how can i free it or remove it..
HP LaserJet... | Answered on Oct 03, 2019
bad toner cartridge. Probably black
HP LaserJet... | Answered on Aug 28, 2019
To select the default language on the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Control Panel Setup], and then press the [OK] button.
More items...
SOLVED: Change language from german to english on p3015 - Fixya
www.fixya.com/support/t12816917-change_language_from_german_english
change the language on HP laserjet 3015 printer Google Search
HP LaserJet... | Answered on Jul 16, 2019
Guys, its easy.. I found a little piece of paper after seeking calmly. It was on the paper pulling system when collecting from the tray. See the pic, it was right whee i'm pointing with my tool. It was locking one of the sensors around there. See in the third image where my tool is pointing.. Its exactly inside and very difficult to see.. And one more thing.. You'll have to unscrew the upper cover to see it.. Good luck
I love smart gadgets like this. Easy to solve. 1d69ed0c-5731-4c6b-ae7c-d49ff90e96d8.jpg 8e1e42b8-3851-411a-98e1-09eb08d019b9.jpg dd6af869-4bf3-4193-af33-57d2d362752b.jpg
HP LaserJet... | Answered on Jun 30, 2019
Go to printer driver make sure you've have legal selected
HP LaserJet... | Answered on May 21, 2019
Need more info. What exactly is happening when that error occurs? ie.. the print job starts and paper feeds through then the error pops up? etc.?
HP LaserJet... | Answered on May 16, 2019
Scanner Error 22
HP LaserJet 8100dn Printer Logo
Popular Tags
6 questions posted
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp 8100 dn error code 57 5 comes up
  • Office Equipment & Supplies
