20 Most Recent HP PhotoSmart 130 InkJet Printer Questions & Answers
You can learn how to set up your printer driver with CD or Without CD. Follow the given steps:
• First, load the software installation CD into the drive and start the Hp printer setup or Installation process from 123.hp.com/setup. In general, your printer device automatically opens the setup.exe.
• If not, you can manually open it by browsing through the computer device.
• Hp printer setup or Installation process is of 3 steps. Prepare, connect and activate. First, they prepare the basic printer setup process.
• Second, the connect displays you a list of software that is going to be installed in your device. Use the Customize Software Selection to change software selection.
• Click on the box "I have reviewed and accept the installation agreements and settings" checkbox and click Next.
• After that, your installer automatically completes the printer driver installation process. Now, the installer automatically detects the printer-computer connection and links the printer with the preferred device.
• The installer might ask you to enter the printer related details like the primary usage and the postal code to get the location information.
• Finally, the activate step lets you register your printer device on the Official Website. For the Activation process, you need an active internet connection.
HP PhotoSmart... | Answered on Apr 22, 2020
It is for sure a matter of settings ..so you have to select the paper type ..and the dimensions ..and also the position ...landscape or portrait ...and after that go for the print..Also select the paper type and size in the printer if it has the feature for it ...It is safer to select there too ..cause from computer you have to make it each time and you may miss something ..
If it is still making problems ..just reinstall the printer 's driver and software from scratch ./..(remove the old one ..and reinstall a clean version of the software ) This way you will be sure it is not an software error..
HP PhotoSmart... | Answered on Aug 03, 2011
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
HP PhotoSmart... | Answered on Jan 28, 2011
Please try to install the driver after downloading it from HP website. Use the link given below, choose your operating system and download the driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=75939&
HP PhotoSmart... | Answered on Mar 28, 2010
Please click the link below to go to the manual download page for your printer:
HP Photosmart 130 manuals
HP PhotoSmart... | Answered on Mar 01, 2010
Mine just had this error and I fixed it by cleaning the big front black roller and the small Grey rollers in the back with q-tips and rubbing alcohol
HP PhotoSmart... | Answered on Sep 29, 2009
You are in luck. I am here to save the day. Have you tried new ink cartridges?
HP PhotoSmart... | Answered on May 31, 2019
Tip
How to Clear error code 0XC19a0037 Ink System Failure on HP Photosmart Printers
This fix will work on all HP Photosmart printers that use 4 cartridges or 5 cartridge #564 or #364 ink cartridges:
on Feb 05, 2019 | HP PhotoSmart Office Equipment &...
if you want help regarding any type of issue in Comcast email then i would recommend you to take help from Xfinity email support team.
visit: https://www.xfinity.com/support/articles/ways-to-get-help
Comcast Email Customer Services 1 888 211 0387 Technical Support
HP PhotoSmart... | Answered on Aug 04, 2018
Hello download the driver here:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=4023244
By selecting the a or b model.
Next select your windows system and download the driver.
Unplug the usb cable when you install the software and connect it again when the installation program tells you to.
Good luck
HP PhotoSmart... | Answered on Feb 17, 2018
HP PhotoSmart 130 InkJet Printer Logo
Popular Tags
11 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
while installing softwear deskjet 130 hp
  • Office Equipment & Supplies
