20 Most Recent HP LaserJet 4345mfp Printer Questions & Answers
install printer Driver
change print port to "Virtual printer port for usb"
use usb line
down load the right firmware .rfu file
in CMD mode,type:
copy /b firmwarefilename.rfu \\pc name\printer name
waitting
it will be down
good luck!
HP LaserJet... | Answered on Mar 14, 2019
You can try to go in the service menu.
You can find this in the administration menu, go all the way down and you will see "service".
You need to insert the service code : 11434506
From there you can reset the maintenance count i guess.
HP LaserJet... | Answered on May 09, 2017
you can scan from adobe photoshop
HP LaserJet... | Answered on Sep 09, 2016
this printer detect paper size error
Delay in printing
HP LaserJet... | Answered on Jul 29, 2016
Bad engine power supply
HP LaserJet... | Answered on Jul 02, 2015
41.3 UNEXPECTED SIZE IN TRA 2
HP LaserJet... | Answered on Jan 14, 2015
You would need to log into the embedded webserver to view the configuration page. From there you could screen capture it as I do not believe that the print config page was added until later models.
HP LaserJet... | Answered on Oct 31, 2014
Check ADF unit (automatic document feeder) working condition.
For diagnoses : Insert few paper(ex:10papers) in ADF unit & do copying, if UR succeed in copying, ADF is working well.. If not check the fault.
HP M4345 facilitated with digital sending option., for configuring digital sending U need to create shared folder with fully permissions in system. Better visit hp site or google to know about how to create folder.. You can do multiple scanning once configuration completed successfully..for more info visit:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c02720194-2%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01&ac.admitted=1409945500358.876444892.492883150
HP LaserJet... | Answered on Sep 05, 2014
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
HP LaserJet... | Answered on Sep 03, 2014
49.XXXX is a fatal catch-all error. Could be firmware problem, network, print job. If the error occurs when you try to print, clear the print queue. If the error occurs when the printer is just sitting idle, reseat the formatter. Try powering on without the network cable attached. If it still happens replace the formatter. Could be a corrupt print job being sent to printer. Print something else.
HP LaserJet... | Answered on Jul 19, 2014
58.XX ERROR To continue turn off then on
A memory error has been detected.
58.4 = Engine power supply
Replace the Engine power supply assembly
(100-127 volt) is part number RM1-1041-000CN
(220-240 volt) is part number RM1-1042-000CN
HP LaserJet... | Answered on Jun 06, 2014
dear friend,
494 c18 error belongs to 3 reason
1- check ur print server Que may be any junk file will be there or error documents will be there.(if you are using windows 7 then it easy to solve}
2-- printer firmware problem- update your printer firmware latest,
3 - check your formatted board
HP LaserJet... | Answered on Mar 28, 2014
dear friend,
for slow print many reasons:
1- check tray adjuster
2- check tray customs or standard lock( it will be right side tray lock)
3- check your printer driver
4- check printer firmware
5-check printer fuser
these are the reasons printer work slove
HP LaserJet 4345mfp Printer Logo
143 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
downld file now send rfu upgrade
  • Office Equipment & Supplies
