20 Most Recent HP LaserJet 4350n Printer Questions & Answers
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to http://www.hp.com for more information
HP LaserJet... | Answered on May 27, 2015
Two reasons: 1. cartridge 2. Trflon sleeve.
A.Check with another cartridgeB.Remove fuser assembly, check teflon sleeve surface,if its dirty or toner deposited on it replace it if you can or replace entire fuser assembly. Replacing the fuser assembly is user friendly.How to remove fusser: browse this youtube video link:
http://www.youtube.com/watch?v=j0Pi-eHgoSA
HP LaserJet... | Answered on Nov 28, 2012
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
HP LaserJet... | Answered on Jun 04, 2012
The problem is not the tuner is the printer drum
HP LaserJet... | Answered on Aug 16, 2010
just select paper type is PLAIN, and everey thing will be good, you have a setting problem , do not worry.
regards
walid sayed
HP LaserJet... | Answered on Mar 23, 2010
Restart the computer in safe mode and try and delete the printer. If that doesn't work download the the Kyocera print driver seleter from kyoceramita.com and use it to delete the driver.
HP LaserJet... | Answered on Mar 06, 2010
First you need to clean the machine. Next you need to try a nother toner cartridge. If it still does it you mite need a fuser.
Also does the paper reach the fuser?
HP LaserJet... | Answered on Jan 22, 2010
sir there will be no ink your printer please check and reply again
HP LaserJet... | Answered on Jun 03, 2009
This is a common problem for the 4350 ( the first series),
they have since then modified them.
the problem come from the Fuser section, there is a gear which starts to wear out and slips,  there is an update for it.
RM1-0043-000CN      Swing Plate Ass'y
HP LaserJet... | Answered on Oct 16, 2007
Most likely the formatter in my opinion.
HP LaserJet... | Answered on Feb 24, 2020
Scanner Error 22
HP LaserJet... | Answered on Feb 20, 2020
thisis the farmetter problem
HP LaserJet... | Answered on Nov 11, 2019
HP LaserJet 4350n Printer Logo
17 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
52 00 error
  • Office Equipment & Supplies
