20 Most Recent
HP Color LaserJet 8550dn Printer Questions & Answers
Error code 49.FF08
you have to clear the printer ques from n/w if connected and restart
1/31/2014 7:57:38 AM •
HP Color...
Answered
on Jan 31, 2014
On our HP8550 printer, we get three error
Bad Transmission is a fault coming from your JetDirect network card.
Try reseating it. (With the power off!)
You could also try swapping it to the EIO 2 Slot. On the back of the device
(Again, with the power off!)
Comms errors will dramatically slow your printing, and can fill the memory with garbage.
9/30/2013 8:45:38 PM •
HP Color...
Answered
on Sep 30, 2013
8550 cold reset
Performing a cold reset
1 Print a configuration page to record the previous
printer settings.
2 Turn the printer off.
3 Hold down GO while turning the printer on. Release GO after
COLD RESET appears on the printer control panel display.
COLD RESET (in English) appears on the display for one second
to verify that the key sequence has been recognized, followed by
the power-on self-test message.
Once the power-on self-test is finished, the message
RESTORING FACTORY SETTINGS displays in English.
9/23/2011 5:33:05 AM •
HP Color...
Answered
on Sep 23, 2011
Can I refill hp 4150A cartridge?
Yes, but it IS important to use good quality toner.
If you've never done this before, be aware that toner is a VERY fine powder, and will go straight through a normal vacuum cleaner filter, and if you do this in the kitchen, 'the wife/fella' (delete as apprpriate) will probably kill you ('cos unless you're careful it will go everywhere)!
4/5/2010 4:41:05 PM •
HP Color...
Answered
on Apr 05, 2010
Top out tray full error on panel of 8550n but
the sensor was jammed so that even though there was no paper in the output tray the printer believed the tray was full. Fixing the jam didn't reset the printer, however, so it was necessary to reboot the printer.
1/7/2010 4:09:15 PM •
HP Color...
Answered
on Jan 07, 2010
8550dn printer showing out of memory message?
If the error is '20.00 Insufficient Memory'
No action required. It is simply out of memory because the file you printed was too big.
If you keep getting the message, simpify the print job and/or add more memory to the device.
You could also..
Change the setting in the <Configuration Menu>, <Clearable Warnings>, from 'On', to "Job'.
This will get rid of the message a bit quicker.
12/19/2009 9:49:40 AM •
HP Color...
Answered
on Dec 19, 2009
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
5/11/2009 2:15:25 PM •
HP Color...
Answered
on May 11, 2009
