20 Most Recent Indesit Genuine Hotpoint Wmf540 Wml520 Washing Machine Door Interlock -c00254755 Questions & Answers
In general, soap dispensers are designed to be integral to the machine. While the machine was put together by human hands and therefore should be able to be disassembled in the same way, it may very well be more of a task than you wish to take on.
This answer assumes the dispenser is basically functional and you have no reason other than cleanliness to want to remove it.
I suggest you clean the dispenser in place and forego removing the unit. I think you will be happier in the long run with this approach.
Good Luck,
Pete
Indesit Genuine... | Answered on Sep 29, 2015
You will have to find the component in the machine that has
gone live to neutral,live to eath or neutral to earth if it is protected by a RCCBO. Check on the back of the printed circuit board for "BLOWS" black marks blown components.
Indesit Genuine... | Answered on Jan 10, 2014
Try cutting the power to the dishwasher (remove the fuse) for about 30 seconds, then when you put the fuse back in, do it quickly and smoothly so you get a clean power-on without a lot of sparking. This may get the dishwasher controller to do a proper hard power-on reset.
If the problem persists, you may have a hardware failure in the controller. The first thing I'd look for is a failing electrolytic capacitor. Sometimes a power on-off cycle finishes them off. Fortunately, the parts are cheap and readily available from online suppliers such as Digi-Key or Mouser. Unfortunately, you have to have electronic component soldering skills to change them. Often, bad capacitors can be visually identified because the top of the capacitor is domed instead of flat, or for smaller units the aluminum casing is partly pushed off of the rubber or plastic base.
bad cap2-u1fciducfz4xg24vis3ttoot-3-0.jpeg Contrast the bad capacitor on the right with the good one next to it on the left.
Indesit... | Answered on Jun 05, 2019
red light flashing indicates a problem. If that is all the symptoms then you need a house call.
Don't know what the salt is about. If t
Indesit... | Answered on May 27, 2019
Try this:
Switch off the appliance by pressing the O N/OFF button. Shut off
the water tap to eliminate the risk of flooding and remove the plug
from the electrical socket.
Make sure the water inlet filter has not become blocked by various impurities. (see "Care and maintenance" chapter)
Indesit... | Answered on Jan 22, 2019
This might sound silly Andy, but there is a cap on the inside floor of the machine thats needs to be topped up with dishwasher granules mate
Indesit... | Answered on Dec 24, 2018
Indesit Genuine Hotpoint Wmf540 Wml520 Washing Machine Door Interlock -c00254755 Logo
11 questions posted
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Bade
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Indesit Dishwashers
  • Indesit Dishwashers
Most Popular Question
remove soap dispenser draw clean
  • Dishwashers
