20 Most Recent Panasonic NN-CD989S New Questions & Answers
I have a Panasonic genius dimension4 nn-9853
Most probably the low voltage transformer of in the control panel is open . It has a thermal fuse which is between pin1 and pin 5 of the low voltage transformer. This fuse is however inside the transformer. If you get a DC resistance of about 350- 400 ohms between pin 5 and 6 of the transormer , connect an external 500ma fuse between pin 1 and pin5
3/31/2024 3:01:10 PM • Panasonic... • Answered on Mar 31, 2024
New NN-T 551 not moving beyond welcome read instructions
It will do nothing until the clock is set.
1/27/2024 1:28:36 PM • Panasonic... • Answered on Jan 27, 2024
Microwave Panasonic NN T551 new does not start even after pressing clock button , no display to set clock . Icon comes only. As : after pressing stop button. No other button gives any response
It seems like you're experiencing an issue with your Panasonic microwave oven NNT551. If the clock button is not responding and you only see two dots when pressing the stop button, there might be a few things you can try to troubleshoot the problem:
  1. Power Cycle the Microwave:
    • Unplug the microwave from the power outlet.
    • Wait for about 30 seconds.
    • Plug it back in and try setting the clock again.
  2. Check for Child Lock:
    • Some microwaves have a child lock feature that can prevent certain buttons from functioning. Check your manual to see if your model has this feature and how to disable it.
  3. Reset to Default Settings:
    • If there is an option in the manual or settings to reset the microwave to its default settings, try doing that.
  4. Inspect for Physical Damage:
    • Ensure there is no physical damage to the control panel or any other part of the microwave that may be affecting its functionality.
1/26/2024 4:53:36 AM • Panasonic... • Answered on Jan 26, 2024
Where can I get the cookery book and operating instructions for the Panasonic NN-K123M microwave, please?
It is here
Panasonic nn-k123 Manuals
ManualsLib https://www.manualslib.com > ... > Microwave Oven Manuals and User Guides for Panasonic nn-k123. We have 1 Panasonic nn-k123 manual available for free PDF download: Operating Instructions Manual ... ..
1/15/2024 5:33:49 PM • Panasonic... • Answered on Jan 15, 2024
How do I replace the interior light in the Panasonic Microwave NN-SD297SR? The microwave is installed above my range. How do I access the light bulb inside the microwave to replace it?
According to videos, Panasonic require removal of the case. Some manufacturers including Panasonic have a small access door on the outside and my Panasonic Catering microwave did.
12/10/2023 6:22:13 PM • Panasonic... • Answered on Dec 10, 2023
2answers
Microwave Panasonic turntable turning when stopped
Your interlock switches are contaminated or worn. Replace the door switches.
12/5/2023 12:11:12 PM • Panasonic... • Answered on Dec 05, 2023
How do I cook an individual frozen pie in my Panasonic convection/grill/microwave
To cook an individual frozen pie in your Panasonic convection/grill/microwave, you can follow these steps: Preheat the oven to 375°F. Remove the pie from its packaging and place it on a microwave-safe plate. Place the plate in the center of the microwave and close the door. Press the "Convection" button on your microwave and set the temperature to 375°F. Set the timer for 25 minutes. Press "Start" to begin cooking. After 25 minutes, check if the pie is cooked by inserting a toothpick into the center of the pie. If it comes out clean, your pie is ready! If not, continue cooking for another 5-10 minutes until it is fully cooked. This is a general guide and there might be variance with your particular device.
10/22/2023 4:43:39 AM • Panasonic... • Answered on Oct 22, 2023
I tried to boil an egg in my panasonic combi oven, it exploded and now the oven wont work.
need to diagnose what circuit[s] were damaged from the egg and water
9/22/2023 12:19:08 PM • Panasonic... • Answered on Sep 22, 2023
Why does my Panasonic 1200w inverter microwave turn off after a minute
Normally thermal overload or failing capacitors. It is worth getting it repaired professionally. Panasonic are the best maker of microwave ovens. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
9/14/2023 5:21:39 PM • Panasonic... • Answered on Sep 14, 2023
Panasonic NN-H965WFX Microwave is visually dead. Could the power relay behind the control panel cause the problem?
Replace the door switches and it may well work again. Mind your fingers becaus 2500 volt is no joke!!!
6/11/2023 10:36:29 AM • Panasonic... • Answered on Jun 11, 2023
Panasonic OTR model NN-S244BL everything works but it doesn't heat up
Does it make a buzzing noise when it's powered on?
5/7/2023 8:05:05 PM • Panasonic... • Answered on May 07, 2023
My panasonic microwave nn-st32hm shows 8888
Try setting the clock.
5/5/2023 12:15:57 PM • Panasonic... • Answered on May 05, 2023
Can a panasonic nn-sn68ks microwave be used over-the-counter, and if so, what are the minimum dimensions of the enclosure to allow necessary venting?
Hi, It can be but not recommended. When mounting over the stove, counter microwave ovens they also include a wall support brackt that is fastened to the wall studs. After it is mounted correctly the microwave has special slots to accept the bracket and after it is on the wall bracket there will be two long screws that screw through the cabinet above it and screw through the holes in the top of the microwave.
3/26/2023 4:58:23 PM • Panasonic... • Answered on Mar 26, 2023
2answers
My Panasonic microwave SD986S shows "service" what can I do to fix it?
I would first try to reset your microwave by pressing and holding defrost button and quick 30 button for 3 seconds.To see if that helps.
3/20/2023 10:46:21 PM • Panasonic... • Answered on Mar 20, 2023
SE985S Panasonic genius plus microwave keeps blowing 20a fuse on average about once a year. Everything works fine for another year after i replace the fuse.
Are other appliances running on the same circuit? Does it happen in the summer with the A/C on? It may be starved for voltage. I've seen this happen on homes where the beaker panel is undersized or has a loose connection.
1/29/2023 11:16:52 PM • Panasonic... • Answered on Jan 29, 2023
When i press it display error in panasonic dimension 4 genuis model nn-c897wbbpq
An "error" message on a Panasonic Dimension 4 Genius model NN-C897WBBPQ microwave oven could indicate a problem with the electronic control system. It is recommend to try resetting the microwave by unplugging it for a few minutes, then plugging it back in. If the problem persists, you should have the microwave checked by a professional technician. You can also try to reset the oven by following the steps in the user manual, which typically involves pressing a certain combination of buttons on the control panel. If the problem is still there, it is advisable to contact the manufacturer or a professional technician for repair. This will help you to get a more accurate diagnosis and a solution to the problem. Depending on the cause of the issue, the cost of repair can vary. It is important to note that, error messages can be caused by various problems, so it is best to refer to the user manual or contact the manufacturer for more specific troubleshooting steps and to get a more detailed diagnosis of the problem.
1/18/2023 6:46:03 AM • Panasonic... • Answered on Jan 18, 2023
Repaired latch inside door, but when I close the door the light stays on and reads close door
Repaired latch inside door, but when I close the door the light stays on and reads close door How To Fix A Stuck Latch If your door can open correctly but can't close without getting stuck, it's likely an issue with the latch. Multiple issues can compromise door latches, such as a mechanical error, worn down latch components, broken door handle cables, and more. If the latch is simply stuck, you should be able to fix this yourself without taking your car to a mechanic. Just take some oil lubricant, like WD-40, and spread/spray it into the latch mechanism of your open door. Let the oil soak in for a little bit, then use a microfiber cloth to rub the oil into any visible parts of the latch. While performing this task, check to see if you can find any rust on latch components. If you do, use a piece of steel wool to scrape the rust away. Once removed, try opening the latch with your door handle to confirm that it is once again functioning correctly. In some situations, your latch may accidentally be closed when it should be open. This can happen for multiple reasons - sometimes due to an electrical glitch or a mistake made while repairing the door. Either way, if you have a car door with a closed latch, try opening your door and looking at the latch to determine its orientation. Then, open a functional door and look at the latch to see how it's supposed to be. A working door will have a latch with "open" jaws. These jaws can catch the door jamb anchor and rotate into a closed orientation to secure the door. If the latch's jaws are already closed, it can't engage with the anchor or close properly. To fix this issue, take a screwdriver and hold the door handle in the open position (pulling if necessary). As you pull the handle, rotate the latch with your screwdriver into the correct orientation. If needed, ask a friend or family member to help you hold the door or hold the handle open for you while you perform this action. Once you have moved the latch into the correct orientation, test the door handle a few times. The latch should open when you pull the door handle, and the door should again be functioning correctly.
1/16/2023 7:33:28 PM • Panasonic... • Answered on Jan 16, 2023
Panasonic NN-CD989S New Logo
2 questions posted
Top Panasonic Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Microwave Ovens
Most Popular Question
h97 fault code panasonic nn cd989s
  • Microwave Ovens
